Showing results for tags 'lag'.
Found 9 results
  1. I just used the magic wand tool in 3DCoat on my current model which has a Mask layer that contains a multi-coloured texture with all my component parts. Firstly, the tool is VERY VERY slow; literally the program froze for about a minute and a half while attempting the operation. I have a model with 7 Materials applied each at 4096x4096. Unfreezing takes just as long to perform. It's a far from ideal situation and I've discovered that sending all layers to Photoshop and doing a mask selection and filling a layer with flat colour is a far quicker operation. Anyone else experiencing this or had problems with the Magic Wand tool in 3DCoat? I'm not sure if it even has a contiguous/non-contiguous setting. Any help/advice appreciated.
  2. Hi! I've been having trouble with slow viewport in sculpt room. On one computer with nvidia rtx 2060, intel i5-9400F 2.90GHz 16GB RAM everything works fine with almost no lag in a really large scene with 92 million triangles. On another computer with nvidia rtx 2080 ti, intel i9-10900K 3.70GHz 64GB RAM its really laggy in the same scene. I've tried doing a clean install of nvidia drivers and reinstalling 3d coat which didn't solve anything. Any ideas what I can try to solve this? Thanks!
  3. Hi all Grabbed myself a copy of 3DC a couple of weeks ago, have been loving it so far. Last week I got the dreaded Win10 popup for the fall creators update - dismissed it with remind me tomorrow, and it installed itself anyway that evening on shutdown (the joy!) Anyway it pretty much messed up my adobe CC installation - all psd's saved out were corrupt, so I decided to reformat my OS drive and start afresh (as I usually do every 6 months or so). Installed 3D Coat again today, and the peformance seems to have taken a massive hit. I'm running in DX Mode, but the viewports lag when rotating and panning, even with just a basic primitive. Have tried toggling cuda on and off, and still the same. PC Specs aren't amazing but wasnt a problem before the update - would have thought it would be better now after the refresh rather than worse! Am running all the latest drivers for the below Any ideas greatly appreciated! Windows 10 Pro 64Bit (Fall Creators Update) i7 6700k (OC'd to 4.5Ghz) 16GB Corsair Vengeance 3200 Gigabyte Geforce 980 Ti Windforce Samsung EVO 850 SSD for OS and 3D Coat installation
  4. Hey everyone! I am currently running into a weird issue. When rotating the camera view with my mouse (in any room), there is a small lag between clicking and the rotating happening. Panning and zooming is not affected by this. Also, this does not happen when using my Macbooks trackpad. This does not happen when using the mouse in Blender either. Does anyone know what could cause this issue? Even though this problem showed up after tweaking the navigation settings to match the navigation I use in Blender, when choosing Custom Navigation -> 3D-Coat (it seems, this sets back the controls), the issue persists. This may seem like a small issue, but it has a strong influence on workflow performance since I'm rotating around objects quite a lot. Hardware used: Macbook Pro 2015, 16GB RAM, 2,8GHz i7 CPU Software used: Mac OS 10.11.6 3D-Coat 4.5.02 If possible, I'd like to not update anything since I'm in the middle of important projects. Best wishes, Shu
  5. So im runing 4.8.03 version of 3dcoat and im trying to do some basic sculpting, im currently using the openggl version and I got i7-7700HQ GTX1050TI and 8gb of ram, I know its not much ram but im working with 250K poligons on surface mode and is laggy as hell in some tools, other tools work fine but some tools, like coat, pose or voxlayer are so laggy im getting really nervous using them. Idk, maybe its the ram, but with 250k i should have no problem, idk if im not doing something properly.
  6. Hi guys, I've been using 3d-coat for a while now and I've come to learn alot about how it works and figured out most of the issues I've encountered. Now the only issue I've got left is that whenever I change tools from Grow to Cut or Transform or any other tool, I get a 4 or 5 second delay and it's really disruptive to my workflow. I was wondering if anyone knew how to fix it? I'm using space bar (quick change menu) to swap tools. The only solution I've come up with so far is deleting my documents folder (the 3D-Coat folder) and re-entering my serial key. Please help! (I've also tried about 50 different client versions.. so that's really not the issue here)
  7. Hi guys! When switching to certain tools I am experiencing a significant delay. Mostly happens in Voxel mode. Cut Off, Pose and Grow brushes are a guaranteed 2-4 second freeze. Some tools work fine, but others take quite some time. It's been happening for a few versions now.. I am wondering whether it is a proper behavior, or there is something wrong on my end. I remember tool switching being instant in the past. Here's a video illustrating the problem: https://www.dropbox.com/s/lq7mrqjcj6ex3y5/3DCoat_SwitchingToolsLag.mp4?dl=0 3DC Version: 4.7.24 Tested in both GL and DX versions CPU: i7-4770 3.40 GHz Ram: 32GB GPU: GeForce GTX 1070 / Driver Version 378.49 Is anyone else experiencing this issue? Cheers,
  8. Hi guys recently I upgraded to the 4.5.19 version of 3dCoat and whenever I change my tool of use, wether I click on the voxel tool or press my shortcut, it has a delay of around three seconds to change to my desired tool. Does anyone else have this problem in 4.5 and more importantly, does anyone know how to fix this? Thanks! Sebastian. Currently have tried all 4 different 3DCoat exe's and they all seem to be doing the same thing.
  9. Hello everyone!! I'm Patrick and I've been using Sculptris up until now. I have some experience with ZBrush too although I don't own a copy of it, I simply had some fun doodling sculpts at a friends house to test the application (his copy). I loved it and will get it for myself eventually. I really like Sculptris too considering it's free in my opinion it gets a few extra points just for that =D I remember looking at 3D Coat a while back and thinking that that I wanted to get it. After a while I simply forgot as other things crept up when I finally had the money to purchase the software... I've returned now to test out the trial again and see what I think of it now. ____________________________________________________________________________________________________ I have one problem with 3D Coat right now but I'm not too sure what you would call it so I'll try and explain my issue and hope that somebody else has had a similar problem but managed to fix it... Before explaining the issue I will give the specs of my machine and operating system: OS - Windows 7 (64bit) Pentium Dual Core processor - 2.70ghz, 2.69ghz RAM - 4gb Nvidia GeForce GT 240 (http://www.nvidia.co..._gt_240_us.html) This I believe is the correct card, I have the 1gb version. ____________________________________________________________________________________________________ Now I don't have the most poweerful machine here and it's a good two or three years old now. The problem I'm having is while sculpting with Voxel, I'm experiencing lag whenever I try to sculpt anything... The main reason I want this software is for the sculpting features. The other features are just a bonus =P I tried having a little look around the internet and these forums to see if anybody else has had any similar issuess and haven't found many people with any similar issue although there was one guy on a forum somewhere but there were no responses to his post. I tried making sure everything but 3D Coat was closed to save resources, I've also tried to update my drivers, I tried reinstalling the aplication and that didn't help either. I've checked the system requirements a couple of times to make sure that I didn't read it wrong or anything and I have the requirements for sure!! Does anybody have any suggestions?? -- I've watched a few videos and what not to check out the application again, I would REALLY love to get in the software and start messing around with the voxel sculpting to get some characters finished up fast and efficiently. Ultimatelly I'm going to get this piece of software but if I cannot get the trial to work without lagging whilst sculpting then I won't be getting it until I can afford to upgrade to a new machine and then purchase this. -- When I say that it lags I mean that it doesn't just have a quick lag spike but it continues to lag until I just wait for it to stop and this occurs every time I try to paint on the basic sphere created. If I decrease the brush size a little it seems to be ok but it's fairly small and I cannot work with that when required to move, push and pull to shape my characters. I should probably end this post here as I've been awake all night and this is dragging on a little.. I initially wnated to say hello to everyone and introduce myself then got to speaking about my little issue with this application in the hopes for someone to help me out with a solution, alternatively I will go ahead and try to install the 32bit version, will this help!? I look real forward to using this software and getting my work up on this forums if I can get the app to run ok with this trial and if so once the trial is up I would more than likely be purchasing it and joining everyone here =] Thanks for reading and sorry for the long ass wall of text!!
