Advanced Member vivi Posted October 29, 2012 Advanced Member Report Share Posted October 29, 2012 basically I wanna select my UV island in the viewport. Because selecting in the UV window is very tiresome since its hard to locate my islands. Is there a way to select them? vito Quote Link to comment Share on other sites More sharing options...
Taros Posted October 29, 2012 Report Share Posted October 29, 2012 Not yet possible. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 29, 2012 Reputable Contributor Report Share Posted October 29, 2012 You can't select them but when you hover your cursor over the area, the preview window shows the island/cluster. Plus, when you select an island in the preview window, that part is highlighted in the 3D Viewport. Quote Link to comment Share on other sites More sharing options...
Advanced Member vivi Posted October 29, 2012 Author Advanced Member Report Share Posted October 29, 2012 You can't select them but when you hover your cursor over the area, the preview window shows the island/cluster. Plus, when you select an island in the preview window, that part is highlighted in the 3D Viewport. this is not a solution...I am faster doing that in 3dsmax. The point is I have MANY islands...small parts..now I have to tweak some...so guessing where my related island are..is too time consuming. I would give this feature request a +1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 29, 2012 Reputable Contributor Report Share Posted October 29, 2012 this is not a solution...I am faster doing that in 3dsmax. The point is I have MANY islands...small parts..now I have to tweak some...so guessing where my related island are..is too time consuming. I would give this feature request a +1 Add this to Mantis and then provide the link here, so others can add their +1 to it. That helps Andrew set priority on feature requests. If you haven't already, just register an account there, and sign in. Then just "Report Issue" and make your request there.www.3d-coat.com/mantis Quote Link to comment Share on other sites More sharing options...
Advanced Member vivi Posted October 30, 2012 Author Advanced Member Report Share Posted October 30, 2012 Add this to Mantis and then provide the link here, so others can add their +1 to it. That helps Andrew set priority on feature requests. If you haven't already, just register an account there, and sign in. Then just "Report Issue" and make your request there. www.3d-coat.com/mantis How to use that Mantis? where do I post something? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 30, 2012 Reputable Contributor Report Share Posted October 30, 2012 How to use that Mantis? where do I post something? Once you sign in, one of the options at the top of the page, is "Report Issue." It's fairly intuitive from there. Quote Link to comment Share on other sites More sharing options...
