How to reset brushes to default
SimonWM
Sorry if this has been answered before but I can't find the search function of the forum. How do one resets brushes? I'll be using several brush sets from Photoshop and I want to be able to reset the brushes to just the few default brushet as I switch from set to set. Thanks in advance.
There is a little toggle in the upper right hand corner of the brush pallet. Click that and choose "Default."
Thank you, I already tried that but it doesn't returns them to default, maybe because I have added some using the plus sign icon in the default folder. How can I clean the default folder without having to go to each of the non default brushes and delete them one by one?
  • 7 months later...
Hi,
I have the same problem, I need to reset or delete A LOT of brushes, but I see no other option than delete one by one or completely delete and reinstall 3dcoat... it seems a complete overkill to me.
I can't believe there is no easier way to deal with this...
Finally got the solution from Andrew:
You my quickly reset any brush folder to default.
- Close 3D-Coat.
- open MyDocuments\3D-CoatV4\textures\patterns\
You may delete files there - all or separately. Each brush representted by 2 files .mclp and .xml
Edited by Zafio
  • 5 years later...
That definitelly is not easy. This should be right click and set to default. There must be an easier way. Other than that, back to Blender and Zbrush.
Oh and it does not work. I just want to reset the alpha of crease live clay brush to deafult. Because I can't find the same alpha in the alpha pallete.
