Advanced Member 3DArtist Posted August 14, 2008 Advanced Member Report Share Posted August 14, 2008 1. Save\Load shortcut keys to a file (useful to share shortcuts between home and work) 2. Customizable (save\load presets) of multiple light setups 3. Occlusion\Cavity Shader 4. HDR Painting and Environmental reflection 5. Shadows I just thought of another: Have the import window (on 3D coat startup) show screenshots of the last 10 (or however many) projects worked on. The screenshots could be automatically created on a save or taken manually via a button in the interface. Quote Link to comment Share on other sites More sharing options...
Advanced Member 3DArtist Posted August 29, 2008 Author Advanced Member Report Share Posted August 29, 2008 I just wanted to kindly bring some attention to this thread again. i know some of these will not be possible in the near future but being able to save/load shortcuts would be really useful for me. Thanks again! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted August 29, 2008 Report Share Posted August 29, 2008 1. Save\Load shortcut keys to a file (useful to share shortcuts between home and work)2. Customizable (save\load presets) of multiple light setups 3. Occlusion\Cavity Shader 4. HDR Painting and Environmental reflection 5. Shadows I just thought of another: Have the import window (on 3D coat startup) show screenshots of the last 10 (or however many) projects worked on. The screenshots could be automatically created on a save or taken manually via a button in the interface. Not so easy to do list Only (1) is easy. Btw, you can take file Options.xml - it has all keyboard settings. Other requests not easy but must be done because visual appearance is important. All this is in plans but I need some time. Quote Link to comment Share on other sites More sharing options...
Advanced Member PoopaScoop Posted September 10, 2008 Advanced Member Report Share Posted September 10, 2008 I think all apart from the shortcuts are pointless. Better to Render it in a render application with all the sugar topings? I really don't want 3dcoats speed to slow down. Quote Link to comment Share on other sites More sharing options...
