Advanced Member Scott Padbury Posted September 1, 2008 Advanced Member Report Share Posted September 1, 2008 I'am loosing alot of the object when I import the object from lightwave it is also flipping the normals and weird things happening. It has alot of detail to begin with so I need some help thanks. I forgot to add that it has not been uvmapped. Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted September 1, 2008 Author Advanced Member Report Share Posted September 1, 2008 Never Mind I think I have got it.. Quote Link to comment Share on other sites More sharing options...
Advanced Member jaf Posted September 2, 2008 Advanced Member Report Share Posted September 2, 2008 Never Mind I think I have got it.. Hi Scott. I wondering what you found out that fixed the problem. I can't even get a plain old six sided cube to import correctly from Lightwave (or Silo). I uncheck the smoothing and select 6 from the drop-down resolution list and select auto-map. But I keep getting a weird looking mesh. I can load that cube in Silo, Vue, Terragen2 or UVMapper Pro, but not 3D-Coat (gl or dx). I assume it's something I'm doing wrong. Quote Link to comment Share on other sites More sharing options...
Advanced Member Monsoon Posted September 3, 2008 Advanced Member Report Share Posted September 3, 2008 Try deleting seams and/or clusters and then let 3dC auto seam it. That seemed to fix any model display issues I've had like this. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 3, 2008 Report Share Posted September 3, 2008 Hi Scott. I wondering what you found out that fixed the problem. I can't even get a plain old six sided cube to import correctly from Lightwave (or Silo). I uncheck the smoothing and select 6 from the drop-down resolution list and select auto-map. But I keep getting a weird looking mesh.I can load that cube in Silo, Vue, Terragen2 or UVMapper Pro, but not 3D-Coat (gl or dx). I assume it's something I'm doing wrong. Stay default carcass resolution. If it will not help, post your cube there Quote Link to comment Share on other sites More sharing options...
Advanced Member jaf Posted September 3, 2008 Advanced Member Report Share Posted September 3, 2008 It's the simplest cube one can make. Six sides -- six poly's. Eight edges. I deselect smoothing and chose "6" from the carcas resolution. Quote Link to comment Share on other sites More sharing options...
Member Auger Posted September 3, 2008 Member Report Share Posted September 3, 2008 It's the simplest cube one can make. Six sides -- six poly's. Eight edges. I deselect smoothing and chose "6" from the carcas resolution. Verified. I get the same results with a cube. A low poly ball works fine. Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted September 4, 2008 Advanced Member Report Share Posted September 4, 2008 seems to be working fine over here: here's the exported cube from Silo 2.1: http://www.wailingmonkey.com/images/3dcoat/cube-test.zip Quote Link to comment Share on other sites More sharing options...
