Advanced Member manticor Posted July 27, 2013 Advanced Member Report Share Posted July 27, 2013 (edited) Would like an option while using transform tool to use middle mouse drag in a direction in empty space which matches closest axis for move ,rotate or non linear scale .this is a default option in softimage and it makes transforming objects really fast .a simple workflow option but increases speed of manipulating objects .also holding Ctrl and tapping a point on another object snap the object to that point would be great too. Edited July 27, 2013 by manticor Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 27, 2013 Report Share Posted July 27, 2013 Camera Custon Navigation Softimage doesnt help ? Quote Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted July 27, 2013 Author Advanced Member Report Share Posted July 27, 2013 (edited) Ok just tried it.firstly the camera navigation doesn't work at all.not even holding down s to navigate works. I use maya style anyway. And nope the middle mouse drag doesn't work either. Worth a try tho .thanks anyway Edited July 27, 2013 by manticor Quote Link to comment Share on other sites More sharing options...
Contributor BeatKitano Posted July 28, 2013 Contributor Report Share Posted July 28, 2013 What about using ctrl+left button drag as default (and modifiable like everything else) since ctrl +move for instance = move along normal. It would be more cohesive with the rest of the UI interaction system. Quote Link to comment Share on other sites More sharing options...
Advanced Member manticor Posted July 30, 2013 Author Advanced Member Report Share Posted July 30, 2013 that could work.Or ctrl +alt .Either way would be good .It just speeds up moving and placing objects Quote Link to comment Share on other sites More sharing options...
