ScrotieFlapWack
Can't Mark Seams :(
So I have run into some issues. I don't know what I am missing. I have created a model in Silo 2, something very simple. I would like to UV it in 3D - Coat, however. When I go to mark the seams 3D - Coat isn't allowing me to select most of the edges of my model to mark the seams :(
I don't know if it is an option I have missed, or whether there has been some slight change to the UV room since I last used 3D - Coat.
Try this please
post-10142-0-39089100-1406415041_thumb.j
Hey Carlosan, thanks for the advise man. I have tried selecting the UV set's. I have made a new UV set as well and still have the same problem :(
are you using retopo room, right ?
If you were doing retopo work with Symmetry on, consider using the apply symmetry to current layer.
You might find that with symmetry active, you're not able to select the half that hasn't been applied, even though you're seeing it because symmetry is turned on.
Edited by alvordr
