Member orlando Posted December 24, 2014 Member Report Share Posted December 24, 2014 (edited) Hello, I have problem using the voxel copy tool. Please see the video. I don't think it's supposed to work that way. https://www.youtube.com/watch?v=DOR9cGFIff0&hd=1 Edited December 24, 2014 by orlando Quote Link to comment Share on other sites More sharing options...
Javis Posted December 27, 2014 Report Share Posted December 27, 2014 Hi, It is working for me in the same build you are using (4.1.17D). Try clearing out your configs first, and retry. Make sure to back up your presets first of course. Also, what are your system specs? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 28, 2014 Report Share Posted December 28, 2014 Copy only work with one Alpha autoselected and is better with pen brushes will you please try to create a new voxel project using an additional extrusion just to try ? Tool Option windows is related to shape contour settings, not to Voxel Copy. Use the first left pen brush for voxel copy, is better. Quote Link to comment Share on other sites More sharing options...
Member orlando Posted December 29, 2014 Author Member Report Share Posted December 29, 2014 Thanks, guys. What do I have to delete to set 3D-Coat in a "reset state"? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 29, 2014 Report Share Posted December 29, 2014 Delete your options.xml file (It's located in your OS user profile folder). This should cure the problem. If not, remove the options.xml and re-install 3DC Quote Link to comment Share on other sites More sharing options...
