Advanced Member Laticis Posted January 7, 2015 Advanced Member Report Share Posted January 7, 2015 (edited) Hi, Is there a way in Per Pixel Painting to always view your mesh without anything smoothing. ( Please see attached ) 1. is how the object appears normally. (because it is triangulated some visual artifacts will show but thankfully do not apply to the maps.) 2. Is with VIEW: Wireframe and Low Poly turned on. (low poly does seem to effect the objects appearance ) 3. Is the objects appearance while the stamp mode is above it and brushes outside of the preview pane. 4. Is the objects appearance while the stamp mode - textured filled. Basically I want to be able to work on my objects how they appear in 3 & 4 - am I missing something ? Cheers Laticis Edited January 7, 2015 by Laticis Quote Link to comment Share on other sites More sharing options...
Advanced Member Laticis Posted January 7, 2015 Author Advanced Member Report Share Posted January 7, 2015 A side by side of the texture fill tool result. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 7, 2015 Report Share Posted January 7, 2015 Are you working at which texture resolution ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Laticis Posted January 7, 2015 Author Advanced Member Report Share Posted January 7, 2015 Normally 4096 x 4096 - but not for images above, it was only set to 1024 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution digman Posted January 7, 2015 Reputable Contributor Solution Report Share Posted January 7, 2015 (edited) I was unsure of the smoothing you are talking about so here are both ways. Importing to the paint room. 3DCoat by default sets the smoothing groups to your object to 90 degrees when importing objects to the paint room or baking from the retopo room. In the import panel, choose auto-smoothing groups and set it to the degrees so desired. Start at 30 and then change it if necessary. The other is texture filter smoothing. Under the View menu turn off Turn off Linear Texture Filtering. No filtering at all, pixels will clearly be seen. Note: 3DCoat does support smoothing groups from other software with out using the auto-smoothing groups feature. I can import a wings3d exported obj file with smoothing groups into the paint room and 3DC imports it correctly... Edited January 7, 2015 by digman Quote Link to comment Share on other sites More sharing options...
Advanced Member Laticis Posted January 7, 2015 Author Advanced Member Report Share Posted January 7, 2015 What an awesome reply Digman, thank you very much. Your first option is exactly what I have been searching for....the one little thing that has been niggling me for so long is now out the way....woo hoo. Very much appreciated mate Cheers Quote Link to comment Share on other sites More sharing options...
