Member 3DNut Posted June 2, 2015 Member Report Share Posted June 2, 2015 I followed a few tutorials that goaded me into really experimenting with customizing my workspace, however I don't see an option to restore everything back to factory default. When I attempt to restore my workspace, I am asked for a file but the problem is I didn't save one before I started moving things around. How do I get everything back to default without a file that I didn't save? Do I really have to move everything back manually or reinstall? Thanks for your help, Bryson Quote Link to comment Share on other sites More sharing options...
Contributor Solution ajz3d Posted June 2, 2015 Contributor Solution Report Share Posted June 2, 2015 To restore workspaces (room layouts), use Windows->Reset this page to default or Windows->Reset all pages to default. If on the other hand you want to reset everything back to their defaults and you're on Windows, type %USERPROFILE%\Documents\3D-CoatV45 (for V4.1.x it's 3D-CoatV4) in Windows Explorer's address bar. This will get you to 3D-Coat user preferences directory. Backup the contents of this folder (just in case) and remove everything but the License.dat file (which holds your license). Start 3D-Coat - it will recreate the default user preferences. Quote Link to comment Share on other sites More sharing options...
Member 3DNut Posted June 3, 2015 Author Member Report Share Posted June 3, 2015 (edited) Wow! "Reset This Page to Default" and "Reset all Pages to Default" are right there in the Windows menu, plain as can be. No wonder why, when I researched this particular issue I couldn't find the question asked before....because if one can read, then the question need not even be asked I appreciate your answer. It has everything I needed to know and more. Edited June 3, 2015 by 3DNut Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted April 29, 2019 Advanced Member Report Share Posted April 29, 2019 (edited) Sorry to necro an old thread but i want to point out that after experimenting with the UI reset this page and reset all pages to default is not working since panels are missing like the smart materials, brush etc. What i did was trying to extend my 3d coat window to my second monitor(Yes serious artists usually use 2 monitors)and then i try undocking the various panels that got extended horizontally and then i tried reset to bring back original position and it is not working at all. I tried re opening all the various panels but they are not dock anymore and trying to dock them like they were at default doesn't work. EDIT: For some strange reasons closing and opening 3d coat 3 time fix it! Edited April 29, 2019 by polynut 1 Quote Link to comment Share on other sites More sharing options...
