Member Stakycake Posted June 7, 2015 Member Report Share Posted June 7, 2015 Hello, I don't find the Stamp tab I used before the last release. Is it still in use ? And if yes, where is it ? I would like to put an image on a surface, but I don't know how without the stamp. Thank you for helping me. Staky Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 7, 2015 Report Share Posted June 7, 2015 Hi ! Do you mean stencil tab ? Quote Link to comment Share on other sites More sharing options...
Member Stakycake Posted June 7, 2015 Author Member Report Share Posted June 7, 2015 Hello carlosan Thank you for your answer. I mean this on the picture below. I did not find it in the popups menu. But in fact I said that thinking about the Material tab before the Smart material. Is it possible to use simple matetrials like before ? I mean, for applying a simple image on a surface ? I think I'm a little bit lost with the new smart material. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 7, 2015 Report Share Posted June 7, 2015 v4.5 introduced different preview for planar/uv mapping of PBR materials. Select each material and adjust the view using Smart Material > Preferred Mapping settings Quote Link to comment Share on other sites More sharing options...
Member Stakycake Posted June 7, 2015 Author Member Report Share Posted June 7, 2015 Ok, thank you carlosan. I will look at this. Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted July 7, 2015 Advanced Member Report Share Posted July 7, 2015 Glad I found this thread. Quote Link to comment Share on other sites More sharing options...
