Advanced Member Ballistic_Tension Posted September 2, 2015 Advanced Member Share Posted September 2, 2015 does it keep track (show you) what colors you have used on your model? meaning if I use say 8 different colors on say 3 different layers and save it then reopen it later ill still be able to see my colors that I used or have a history layer. also can you copy all paint used on a layer or object and paste /apply it on a different part of your model. it drives me crazy and waste time trying to find what colors I used on models. I use blender and when I create a new color/material it stays there and I can name it also when I use the color picker it gets chosen but I use it mostly for modeling thanks. Quote Link to comment Share on other sites More sharing options...
Advanced Member moska Posted September 7, 2015 Advanced Member Share Posted September 7, 2015 i don't use painter,sorry.but theres some tutorials,anyway better check with them. hope this helps Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted September 8, 2015 Author Advanced Member Share Posted September 8, 2015 Yeah I have seen some SP Tutorials I see that sp shows you your brush settings and material setups which is called a Tool.it also keeps a history of brushes used . I would like to know if you /when you reopen that file/object that you had done work on is all that information still going to be there. its not in 3dc at all which for the life of me it should be in there right out of the gate. how can you see what you have used on a model other then writing down all the RGB info (fyi when I try those same value # s in blender I get a different color) and what stencil you have used etc.. just looking for a paint program with more info feed back/history SP seams to be it but like most tutorials don't reopen a old project. thanks any way I though I was going to get another zero post on this lol Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted September 8, 2015 Contributor Share Posted September 8, 2015 Could you show me a tutorial where you see that history, please? Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted September 8, 2015 Author Advanced Member Share Posted September 8, 2015 Youtube: allegorithmic substance painter tutorial - Fundamentals 09 : painting and brush settings Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted September 8, 2015 Contributor Share Posted September 8, 2015 (edited) As far as i see, then yes. If you save your brush as Tool it is stored as new Tool with all informations of Material, Stencils and stuff like that. After you reload or open a new file, it you could use it for a new project or to work again with it. But there is no history as far as i see. If you work with 10 different Materials and stencils, you have to create 10 Tools. Edited September 8, 2015 by Malo Quote Link to comment Share on other sites More sharing options...
Advanced Member Ballistic_Tension Posted September 19, 2015 Author Advanced Member Share Posted September 19, 2015 as far as I can see SP and Blender have no app-link? or external progress per say I see Houdini 15 is getting some attention .Also it says internal gpu not recommended the very thing I have NVidia gtx 745 . Quote Link to comment Share on other sites More sharing options...
Contributor Malo Posted September 19, 2015 Contributor Share Posted September 19, 2015 No, not every software have an Applink. You still have to use fbx or obj for the exchange. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 21, 2015 Share Posted September 21, 2015 KenJiang saidMy Texturing Steps:0. Bake all the necessary maps from the high poly. (low poly needs to be exported as fbx if you have multiple UVs)1. Create procedural material templates (with tweakable parameters exposed) for each material in SD5.2. Assign base materials exported from SD5 on the low poly in Substance Painter.3. Define and paint material details in SP.4. In the first shading group, wrap the hand painting details and layers and save them as smart materials.5. Apply the smart materials on the rest shading groups.6. Detail Refinement.All the templates and smart materials are created to be reused. Quote Link to comment Share on other sites More sharing options...
