Big time problem going into Lightwave
Hi there,
I just tried to paint some simple textures and color on my model and when I bring it into Lightwave from 3D Coat and hit tab to smooth the model, I get a weird problem, every poly has a freakish blend to it (see attached). I'm not sure if it's a Lightwave bug or a 3D Coat bug, but if anyone has a answer on what to do or try, I would greatly appreciate it. I attached both the un-smooth and smoothed set from Lightwave so you can see the difference.
Thanks
Jim
post-2556-0-03043500-1446614678_thumb.pn
post-2556-0-73245600-1446614702_thumb.pn
Hi carlosan,
In blender, can you put any texture onto him and see if he's wiggling out texture wise. In light wave, if I look at him in simple wire shade he looks fine, it's when I look at him in texture mode that all the wiggling out happens. In light wave forum someone thinks it could be a vertex map that generated that is causing this so I'll take a Look soon. I really appreciate you trying to help me! :)
