Member ConsciousActs Posted January 10, 2016 Member Share Posted January 10, 2016 I was attempting to apply the Vox Extrude tool after making a selection, the layer was in surface mode, but it was the only layer visible. There were several other layers but they were turned off. I was having some odd behavior with the auto-save previously where I would see the counter counting down and I would ctrl-s save, which would cause the count-down to disappear as it should but then it would re-appear and start counting where it left off before I saved, as though it wasn't recognizing my save attempt. Then, when I put my above note into the crash reporter and tried to send my crash I got this error: Fatal error: Cannot access empty property in /var/www/vhosts/3dcoat.com/httpdocs/typo3conf/ext/bug_report/pi1/class.tx_bugreport_pi1.php on line 107 So I've attached my crash output to this post as well as the above comments. Hope that helps fix things! Quote Link to comment Share on other sites More sharing options...
Member ConsciousActs Posted January 10, 2016 Author Member Share Posted January 10, 2016 Had a second crash trying to use the voxlayer command—it memory-leaked and then crashed when it didn't complete the operation. Bug report output attached (since the auto-reporter isn't working). Quote Link to comment Share on other sites More sharing options...
Member ConsciousActs Posted January 10, 2016 Author Member Share Posted January 10, 2016 I'm not sure attachments got attached, so dropbox links:https://www.dropbox.com/s/cdxcw27h9eauxpm/2016.1.9.3dCoatCrash.txt?dl=0 https://www.dropbox.com/s/1846xbc20rmkobw/2016.1.9.3dCoatCrash2.txt?dl=0 Quote Link to comment Share on other sites More sharing options...
Member ConsciousActs Posted January 10, 2016 Author Member Share Posted January 10, 2016 Third crash this morning—I opened the file to try again and try to work-around: 1) duplicated the layer I'm trying to operate on. 2) converted layer to voxel representation 3) chose the vox extrude tool 4) made a single brush impression selection (so it'd be small) 5) Hit "apply" ... 6) Note bug information https://www.dropbox.com/s/iyhzr18tztvdlla/2016.1.9.3dCoatCrash3.txt?dl=0 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted January 10, 2016 Share Posted January 10, 2016 reported to support@3d-coat.com ty ! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 10, 2016 Share Posted January 10, 2016 Looks like mesh structure corrupted, please send, if possible, the mesh to support@3d-coat.com And could be good to see screenshot where settings and shape of selection is visible. Quote Link to comment Share on other sites More sharing options...
Member ConsciousActs Posted January 11, 2016 Author Member Share Posted January 11, 2016 (edited) I have sent an email—now can I get access to Mantis fixed for regular bug reporting purposes going forward? Also, suggestions for fixing auto-reporter if it's something on my end with that error? Contrary to the 'closed' status on this thread here: http://3dcoat.com/forum/index.php?showtopic=18729 this isn't resolved yet ;-) Edited January 11, 2016 by ConsciousActs Quote Link to comment Share on other sites More sharing options...
Solution Carlosan Posted January 11, 2016 Solution Share Posted January 11, 2016 resolved Quote Link to comment Share on other sites More sharing options...
