Advanced Member herve_bis Posted September 5, 2016 Advanced Member Report Share Posted September 5, 2016 hello. Trying to bake to a 16k map does not work for me.. max I can is 8k with a 4GB GTX 980 ... Would 8GB work..? or do I need 12GB ? Thank you Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 5, 2016 Report Share Posted September 5, 2016 Testing to bake a 16k texture using a simple bake, same issue for me. Baking process takes long time freezing the comp. I drooped a mail with your request at support@3dcoat.com Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 5, 2016 Author Advanced Member Report Share Posted September 5, 2016 oki, Thanks a lot Carlosan I thought that would be a ram issue, but I have 128 GB... When trying on a very simple model, it goes up to 22GB... then nothing happened, and 3D Coat Not responding. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 5, 2016 Report Share Posted September 5, 2016 I tried a bit sculpted sphere + retopo simple patch, bake 16 K. Baked successfully. I have 4gb VRAM + 32 gb RAM. Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 5, 2016 Author Advanced Member Report Share Posted September 5, 2016 Hello Andrew... well you got lucky... No idea why it does not work.. also Trying to open a simple plane in the Paint room (per pixel) and setting the texture to 16k does not work either.. I wonder why though.. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 5, 2016 Report Share Posted September 5, 2016 Try what I done. Sphere + LC strokes + patch 64 polygons + bake 16K Does it work for you? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 5, 2016 Report Share Posted September 5, 2016 Andrew, which nVidia driver version have you installed ? ty ------------------------------------ make a primitive cube autoretopo 20K polys autoseams, unwrap bake for PPP, 16K texture 3DC hangs the PC. Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 6, 2016 Author Advanced Member Report Share Posted September 6, 2016 well I tried your path Andrew.. but without Luck... could it be a driver issue..? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 6, 2016 Report Share Posted September 6, 2016 Try to bake without baking AO. Just uncheck the checkbox. Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 6, 2016 Author Advanced Member Report Share Posted September 6, 2016 Hello Andrew... thank you for your patience Where do you uncheck baking AO, I can't find it... Am I missing something..? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 6, 2016 Report Share Posted September 6, 2016 Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 6, 2016 Author Advanced Member Report Share Posted September 6, 2016 Ahh oki... well I tried, but no luck... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 6, 2016 Report Share Posted September 6, 2016 Bake NM with dithering is = ON ? Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 6, 2016 Author Advanced Member Report Share Posted September 6, 2016 Hello Carlosan.. mmm nope it was off... btw, what I do need anyway is Bake PPP with disp. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 6, 2016 Report Share Posted September 6, 2016 off, ok. just asking to know every variable. Is not needed. Ty Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 7, 2016 Author Advanced Member Report Share Posted September 7, 2016 On 5.9.2016 at 5:20 PM, Carlosan said: Andrew, which nVidia driver version have you installed ? ty ------------------------------------ make a primitive cube autoretopo 20K polys autoseams, unwrap bake for PPP, 16K texture 3DC hangs the PC. That would be nice to know... Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 7, 2016 Report Share Posted September 7, 2016 2.11.4.0 Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 7, 2016 Author Advanced Member Report Share Posted September 7, 2016 Hello Andrew thank you. Well.. I updated the driver... restarted the comp... but 3DCoat crashes now at start-up... so I re-installed it... no effect.. still crashes upon starting the app. no idea what to do... Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 7, 2016 Author Advanced Member Report Share Posted September 7, 2016 I have DL the new beta and all I get is this now.. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 7, 2016 Report Share Posted September 7, 2016 Have you an antivirus installed ? Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 7, 2016 Author Advanced Member Report Share Posted September 7, 2016 (edited) Hello Carlosan.. yes I have Kaspersky.. PS. I disabled it but no luck;... and now I get this message Edited September 7, 2016 by herve_bis add Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 7, 2016 Report Share Posted September 7, 2016 Please drop a mail at support@3dcoat.com ty Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted September 7, 2016 Report Share Posted September 7, 2016 Possibly option files are corrupted, try to delete Options.xml in User/3D-CoatV47/ 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted September 7, 2016 Author Advanced Member Report Share Posted September 7, 2016 Hej Andrew.. Thank you, that solved it.. and in fact it also solved the 16k baking problem 1 Quote Link to comment Share on other sites More sharing options...
