Member vladius Posted September 30, 2016 Member Report Share Posted September 30, 2016 (edited) OK, I've decided to make some verbose testing to diagnose the spacing issues that I've met so far. Anyways, I welcome everybody to my journey for perfection. So far I've made the following tests with different Spacing and drawing types configurations. Stay tuned! Hope that the devs will see this thread, as I think the whole story is very important. Edited September 30, 2016 by vladius Quote Link to comment Share on other sites More sharing options...
Member vladius Posted September 30, 2016 Author Member Report Share Posted September 30, 2016 (edited) Using Absolute tool in Surface Sculpt mode. Current discoveries: 1. Even when you turn Spacing off, there is still spacing applied. And there is even more to it. In fact, if you turn on Spacing but set it to some low value of 1% (or even %0.1) the resulting spacing is *lower* than that of using no spacing at all. This is a very cheesy behavior, if you ask me. @developers: Make UI clear, that using Spacing with low values produces more sampling than using no Spacing atl all. 2. Spacing and curve segmentation are different things. You can decrease spacing with low spacing values, but the segmentation settings seem to be built-in and brush-size-dependent. @developers: Make curve segmentation explicit, just like spacing is. Make some kind of Detail value, that would define how many steps are sampled during a single curve segment. Edited September 30, 2016 by vladius Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 30, 2016 Report Share Posted September 30, 2016 Please drop a email at support@3dcoat.com with your Spacing Issues Research. Ty ! Quote Link to comment Share on other sites More sharing options...
Member vladius Posted September 30, 2016 Author Member Report Share Posted September 30, 2016 Using normals-only Brush tool in the Paint room. Current discoveries: 1. As in Sculpt room, the minimal spacing is better than no Spacing at all. @developers: Make UI clear, that using Spacing with low values produces more sampling than using no Spacing atl all. 2. Brush with a 1% spacing produces perfect result. @developers: Do nothing with this case =D Try to produce similar results for the Sculpt room, please. Quote Link to comment Share on other sites More sharing options...
Member vladius Posted September 30, 2016 Author Member Report Share Posted September 30, 2016 3 minutes ago, Carlosan said: Please drop a email at support@3dcoat.com with your Spacing Issues Research. Ty ! Ok, will do it right now. Thank you for your response. Quote Link to comment Share on other sites More sharing options...
Member vladius Posted September 30, 2016 Author Member Report Share Posted September 30, 2016 I have found one more perfect scenario and it's in the Paint room as well. The per-pixel normals + displacement mode still yields perfect results with a 1% Spacing. Seems like the Paint room's algorithms do sampling just right, both affecting curve segmentation and brush alpha placement. @developers: If it hard to derive automatic values in the Sculpt room, make them at least totally explicit to the user. Quote Link to comment Share on other sites More sharing options...
Member vladius Posted September 30, 2016 Author Member Report Share Posted September 30, 2016 One more issue was found while working on this: http://3dcoat.com/mantis/view.php?id=2201 The curve, consisting of multiple sub-curves is not applied at once, but layer by layer instead. That causes some undesired overlapping issues. Quote Link to comment Share on other sites More sharing options...
Member vladius Posted October 1, 2016 Author Member Report Share Posted October 1, 2016 For the last issues, I have found a workaround. Uncheck the Additive Painting flag in the Depth channel paint options to get identical results for sub-curve crossings. See the illustration: 2 Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted October 1, 2016 Contributor Report Share Posted October 1, 2016 Thanks for the tips! Quote Link to comment Share on other sites More sharing options...
