Advanced Member Ratchet Posted November 17, 2016 Advanced Member Report Share Posted November 17, 2016 (edited) Hi, For Retopology room or Voxel Room having a Pie context menu would help a lot, instead of having to pick up tools on a window you got a pie menu appearing under your mouse to quick access to possible tools for the selected object. Another great feature is a Quick Pick bar like Zbrush, it stacks all tools you are using when you start a new work session, so you get a quicker access to the tools you use more often. These improvments speed workflow a lot when there is too much key shortcuts. Edited November 17, 2016 by Ratchet Quote Link to comment Share on other sites More sharing options...
Carlosan Posted November 17, 2016 Report Share Posted November 17, 2016 There is a Quick Pick bar like Zbrush. Use the space bar for that. ---------------------------------------- Suggestion: Coul you ask first about the function instead of assuming that it does not exist and create new feature requests based on the lack of knowledge of the software ? Ty. http://3dcoat.com/manual/ Quote Link to comment Share on other sites More sharing options...
