Advanced Member Richard A. Posted December 15, 2016 Advanced Member Report Share Posted December 15, 2016 Hi, Any tutorials, vids if possible, for fixing texture seams? I have set up Dusk from Hivewire with a texture map I made but there are some noticeable seams between the head to the top of the head and under the neck I need to fix. I have exported Dusk with the maps so that's loaded up in 3DCoat. I tried to understand how using a texture map as a "source" to fix the seams but nothing happens when I use the brush so I'm a loss. Thanks for the help! Richard Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 16, 2016 Report Share Posted December 16, 2016 Clone tool is useful for you ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Richard A. Posted December 16, 2016 Author Advanced Member Report Share Posted December 16, 2016 That would be fine but I'd like an in depth tutorial, video if possible, on how to use the brush or clone tools. As stated I loaded up the face texture to use as a source and when I tried to use the brush tool nothing seemed to happen. So not sure how to go about this! Thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 20, 2016 Report Share Posted December 20, 2016 Quote Link to comment Share on other sites More sharing options...
Advanced Member Richard A. Posted December 20, 2016 Author Advanced Member Report Share Posted December 20, 2016 Hi and thanks. Yes, I did find this beginners series. I do know how to use the cloning brush in PS so that's fine but I don't know if it's how I imported in my premapped model or what but when I try to use the cloning brush or even the paint brush nothing happens. So something isn't right. Any tips to try to troubleshoot that? Thanks again! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 20, 2016 Report Share Posted December 20, 2016 can you share the project to take a look ? Quote Link to comment Share on other sites More sharing options...
Advanced Member Richard A. Posted December 21, 2016 Author Advanced Member Report Share Posted December 21, 2016 Not sure how to do that as it's pretty heavy map wise. If there is a correct and an incorrect way to import in the mapped model that would be helpful to know. that well may be what's going on. Thank you! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 21, 2016 Report Share Posted December 21, 2016 Im shooting in the dark, is hard to suppose... Are you working in the correct layer ? What if you begin a new project using the default options ? The clone tool works fine / Quote Link to comment Share on other sites More sharing options...
