Member nguyenhh Posted January 1, 2017 Member Share Posted January 1, 2017 I need help/guides on how to install 3D coats contents such as: brush, shader, material... I have downloaded them but cannot figure out how to import/install them. Many thanks in advance Best Regards nguyenhh Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/ Share on other sites More sharing options...
Carlosan Posted January 1, 2017 Share Posted January 1, 2017 Hello ! - File - Import extension Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-142901 Share on other sites More sharing options...
Member nguyenhh Posted January 2, 2017 Author Member Share Posted January 2, 2017 Got it Thanks 1 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-142905 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 On 4.7.19 and on the latest build 4.7.24, I'm not able to install the extensions properly from the community resources. I see a tab in the paint room that shows e.g. "Bricks" under Smart Materials tab but there are no shaders in there after a restart. Just X "close" and +"New". This is the same for the shaders in the Voxel sculpt room. Is there a way to manually install the 3dpack contents to the appropriate location? Best Regards, Jason Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143847 Share on other sites More sharing options...
Carlosan Posted February 17, 2017 Share Posted February 17, 2017 Is a compressed file. You can uncompressed it using 7-zip (as example) Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143857 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 I see that it's a zip file now. However I'm still not able to load it into the various menus, aargh. Thanks for the reply though. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143866 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143867 Share on other sites More sharing options...
Carlosan Posted February 17, 2017 Share Posted February 17, 2017 Because you need to copy the folder to user documents folders location -patterns- C:\Users\username\Documents\3D-CoatV___ Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143869 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 File>Browse>Smart Materials Indicates 3D coat is looking in it's install folder here: C:\Program Files\3D-Coat-V4.7.19\patterns However the installer places them in my docs folder (Hate my docs) Not sure if I should leave this alone or try to get 3Dcoat to not look at install folder but repoint it to my docs..? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143870 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 Look at first screen shot, the "bricks" are in fact in the documents folder already. So are some of the other resources, yet 3Dcoat doesn't see them. I try to manually load them by going to the Smart Material>Bricks>tab and select add to existing but it's not reading the xml, instead it's just bringing in the associated bitmaps flat into that folder. I can't pick the xml file either from that menu, only the bitmaps. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143871 Share on other sites More sharing options...
Member co3Darts Posted February 17, 2017 Member Share Posted February 17, 2017 Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143872 Share on other sites More sharing options...
Carlosan Posted February 18, 2017 Share Posted February 18, 2017 If you found materials at 3DC website http://3dcoat.com/download/#3 That are legacy materials for version 3. Are not compatible with version 4.7.x Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143886 Share on other sites More sharing options...
Member co3Darts Posted February 18, 2017 Member Share Posted February 18, 2017 Well that would at last explain it. Thanks but it doesn't say anything about version compatibility does it? Is there a location for some of these that are compatible with v4? Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143888 Share on other sites More sharing options...
Carlosan Posted February 18, 2017 Share Posted February 18, 2017 Yes, you can search this subforum http://3dcoat.com/forum/index.php?/forum/31-3d-coat-exchange-library/ Many users like to share their materials. Hope it help Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143891 Share on other sites More sharing options...
Carlosan Posted February 18, 2017 Share Posted February 18, 2017 Take note if you upload to version 4.7.24 For improvements in PBR shaders many materials are no longer compatible. You need to Convert materials pre 4.5 - And to use Migration Master command Quote Link to comment https://3dcoat.com/forum/index.php?/topic/20573-3dcoat-content-installation-migration/#findComment-143892 Share on other sites More sharing options...
