Member Haunted Posted March 2, 2018 Member Report Share Posted March 2, 2018 (edited) Hi, I found a funny "bug": Resizing a docked Window to "zero" makes the UI "self aware" :P See the Video Also I would like to ask if there is a problem with the Material Preview with the Edu Version (2k texture Limit). The preview looks more detailed than possible for the texture to be. This time I made sure Opacity is at 100%. Here's the Video (sorry, always forget to turn down my music when recording :D) Edit: I should add that I aim to use 2048 texture size to use for games. So it would be nice if the preview would show the 2048 result instead of the 16k one (?). Unless I am missing something here. Edited March 2, 2018 by Haunted Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted March 2, 2018 Reputable Contributor Report Share Posted March 2, 2018 The preview uses a higher resolution than what that default object has. Go to the TEXTURES menu > Mesh and Texture Resolution > change it to 4k. You will see a closer correlation between the preview and the filled model. Quote Link to comment Share on other sites More sharing options...
Member Haunted Posted March 2, 2018 Author Member Report Share Posted March 2, 2018 Hi, it's already set to 2048 :/ Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 2, 2018 Report Share Posted March 2, 2018 Yes, the Edu Version has a texture limit of 2k. Quote Link to comment Share on other sites More sharing options...
Member Haunted Posted March 2, 2018 Author Member Report Share Posted March 2, 2018 (edited) 10 minutes ago, Carlosan said: Yes, the Edu Version has a texture limit of 2k. Yes, that's okay to me. But how do I set the preview to be 2048 too? At the moment it seems to always show the best quality possible. Even when I set my texture size to 64x64. Preview is always HQ. It's not a big issue, but that makes the preview window rather useless when working with lower resolutions. Edited March 2, 2018 by Haunted typo fixed Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 3, 2018 Report Share Posted March 3, 2018 At the moment it always show the best quality possible by default.Cant be changed. Quote Link to comment Share on other sites More sharing options...
