Advanced Member Scott Padbury Posted February 18, 2009 Advanced Member Report Share Posted February 18, 2009 Can you export out voxels at a lower mesh after sculpting to say Lightwave format which I use? I brought in a low resolution mesh to play around with and I used sculpt to see what I could do with it. I'am a Newby to this. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted February 18, 2009 Report Share Posted February 18, 2009 Can you export out voxels at a lower mesh after sculpting to say Lightwave format which I use? I brought in a low resolution mesh to play around with and I used sculpt to see what I could do with it. I'am a Newby to this. Press RMB in VoxelTree There are several choices to export: 1) Export directly high poly mesh - use VoxTree->RMB->Export->... or File->Export menu 2) Export low-poly with all details - VoxTree->RMB->Quadrengulate and paint, export mesh from File menu. 3) Export rough lo-poly mesh - VoxTree->RMB->Quadrangulate, export Raw mesh from Retopo menu Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted February 18, 2009 Author Advanced Member Report Share Posted February 18, 2009 Press RMB in VoxelTreeThere are several choices to export: 1) Export directly high poly mesh - use VoxTree->RMB->Export->... or File->Export menu 2) Export low-poly with all details - VoxTree->RMB->Quadrengulate and paint, export mesh from File menu. 3) Export rough lo-poly mesh - VoxTree->RMB->Quadrangulate, export Raw mesh from Retopo menu Thanks Andrew you are the man.. My next stupid question is, where do I find the voxeltree? Quote Link to comment Share on other sites More sharing options...
Advanced Member lc8b105 Posted February 18, 2009 Advanced Member Report Share Posted February 18, 2009 Thanks Andrew you are the man.. My next stupid question is, where do I find the voxeltree? If you are using the latest Alpha, here is the VoxTree panel: Quote Link to comment Share on other sites More sharing options...
Advanced Member Pimpmymonkey Posted February 18, 2009 Advanced Member Report Share Posted February 18, 2009 Thanks Andrew you are the man.. My next stupid question is, where do I find the voxeltree? Hi Scott, I hope this helps. P. Monk Quote Link to comment Share on other sites More sharing options...
Advanced Member Pimpmymonkey Posted February 18, 2009 Advanced Member Report Share Posted February 18, 2009 @ lc8b105 Wow you are fast. P. Monk Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted February 18, 2009 Author Advanced Member Report Share Posted February 18, 2009 @ lc8b105Wow you are fast. P. Monk Sorry I guess I was not using the Volumetric just the Sculpt mode.. So how to I get the sculpt mode to a lower resolution for export? Quote Link to comment Share on other sites More sharing options...
