Ok,stupid question, Can you export out voxels at a lower mesh
Scott Padbury
Can you export out voxels at a lower mesh after sculpting to say Lightwave format which I use? I brought in a low resolution mesh to play around with and I used sculpt to see what I could do with it. I'am a Newby to this.
Press RMB in VoxelTree
There are several choices to export:
1) Export directly high poly mesh - use VoxTree->RMB->Export->... or File->Export menu
2) Export low-poly with all details - VoxTree->RMB->Quadrengulate and paint, export mesh from File menu.
3) Export rough lo-poly mesh - VoxTree->RMB->Quadrangulate, export Raw mesh from Retopo menu
Thanks Andrew you are the man.. My next stupid question is, where do I find the voxeltree?
