Member GrzegorzWięcek Posted July 19, 2018 Member Report Share Posted July 19, 2018 Hello guys, I was wondering for a long time untill now, how can I paint stitches, cloth seams on low poly objects. Should I use alpha brushes? or sculpting brushes to this purpose? There are some Z brush sets but I'm not sure if I should do it in Sculpting room, or Paint room. Could I create a brush in Photoshop and paint on a texture normal map ? Sory, I'm bit confused, is it painting stil,l or is it sculpting matter already??? if you know what I mean Thanks in advance Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted July 19, 2018 Contributor Report Share Posted July 19, 2018 Sculpt room detail gets baked in Retopo and has way more choice in brushes and techniques than Paint room. Paint room has PBR. At anytime you can link to PS. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 20, 2018 Report Share Posted July 20, 2018 Paint strips tool will help too. Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 20, 2018 Author Member Report Share Posted July 20, 2018 Thanks guys, although your advice are very handy and helpful, and I will take a closer look to them, it wasn't exactly what I was looking for. I need to achieve very high level of realism like I attached in the image below the post. Some time ago I found a tutorial from Poliigon.com presenting a brush sets like this Can I use them in 3D Coat? Can I create them by myself in Photoshop like this guy Arrimus 3D is doing on this second tutorial?? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 20, 2018 Report Share Posted July 20, 2018 Please check this Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 20, 2018 Report Share Posted July 20, 2018 Strips Strips allow you to make repeating patterns along your strokes. Strips use black and white images, similar to Brush Alphas. The Strip will also be filtered through your Brush Alpha, allowing for more advanced painting effects. A example of using a Strip, is stitching on clothing or shoes, bullets on a bandolier, etc. Strips work primarily in the Paint Room, but can also be used with some of the sculpting tools in the Sculpt Room. Strips do not work in any other room. 1 Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 22, 2018 Author Member Report Share Posted July 22, 2018 On 7/20/2018 at 12:03 PM, Carlosan said: Strips Strips allow you to make repeating patterns along your strokes. Strips use black and white images, similar to Brush Alphas. The Strip will also be filtered through your Brush Alpha, allowing for more advanced painting effects. A example of using a Strip, is stitching on clothing or shoes, bullets on a bandolier, etc. Strips work primarily in the Paint Room, but can also be used with some of the sculpting tools in the Sculpt Room. Strips do not work in any other room. Thank you so much. I will follow your advice then Have a good day Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 23, 2018 Author Member Report Share Posted July 23, 2018 54 minutes ago, GrzegorzWięcek said: OK, so I'm getting closer to what I'm looking for, but still, there is something wrong with these alpha brushes Check out attached image. When I paint it creates this unwanted circle around the alpha area. In the preview window alphas looks fine, without any circular shape around Any ideas what I did wrong? Screen Shot 2018-07-23 at 13.14.35.psd sorry, I made a mistake while creating my brush, now it works fine, how can I delete my last quote (above) Thanks a lot. 1 Quote Link to comment Share on other sites More sharing options...
Member GrzegorzWięcek Posted July 23, 2018 Author Member Report Share Posted July 23, 2018 Let me share with you this couple of renders, as a final solution to my issue guys it is a great joy to work in 3DCoat. 2 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted July 23, 2018 Report Share Posted July 23, 2018 Quote Link to comment Share on other sites More sharing options...
