Dmitry Bedrik
Incorrect Curve Stroke mode.
 I thought that in drawing mode "Stroke Curve" any tool would act directly below the line. However, it is not. For some reason, the impact is shifted relative to the line. Either the tool is buggy, or it initially does not work the way most normal users understand it.
Pinch default value is 100%, are you using 0% for any reason ?
It's a perspective issue.  The mesh is altered not from your veiwport but directly under where the stroke occurs on the surface of the mesh.
Edited by Falconius
In any case, it works incorrectly and completely illogical.
I disagree, seems logical for it to alter the mesh where the line falls on the mesh, and indeed if you wrapped it around the mesh in 3d space it would still work.  If it just popped up directly towards the view port not only would that cause problems any time you used it in non-orthographic mode, but it wouldn't work for any lines defined in 3d space.  There are plenty of nice tools that do things based on the view port, perhaps try one of them instead?
It seems that you do not understand the essence of my post. Instead of performing the operation in the same way as the "Brush along the Curve" or "Vertex Lines" option, the result of the operation appears somewhere off the "Curve Stroke".
