3D Coat Forums
lululee
[Solved] how to install multiple brushes
Hi,
I downloaded some brushes (3DC_Brushes_05.3dcpack)
Do I have install them 1 at a time or is there a way to drop them into a folder together?
Cheerio
lululee
3dcpack is only a zip file renamed, to be unpacked by 3DCoat. you could just change the 3dcpack file to .zip and then you will be able to extract them and move the content to Documents\3D-CoatV48\
even if you had a folder full of TIFF files for example (which is the only format that doesn't get replaced by a mclp file) you could drop all the TIFF files in a folder at 3D-CoatV48\textures\patterns and the folder with all those alphas would be read by 3DCoat and you don't need to manually do anything, you can even do a change on a Tiff file, delete the xml and mclp file that would be generated and then a new one will be generated again (reason why Tiff is the best format in my opinion).
Hi
Using latest version you can install all together. Its a new feature.
31.01.2019 4.8.33
- Importing multiple 3dcpacks
