Can't find a window
Kelleytoons
That's the Tool Options panel docked there, not all tools have it. In this case I think it is the Transform tool the one selected that show all those options.
If you want to have it, just go to Primitives, Transform, Curves, or many of the tools in Adjust or Objects section and 3DCoat will display the panel and then you can dock it if you want or just use it whenever you use a tool that has options.
