Advanced Member polynut Posted June 3, 2019 Advanced Member Report Share Posted June 3, 2019 Hi guy's, I was looking for a way to scale uniformly with the tool bar scale option? Is there a shortcut to make it scale uniform? There is an unlock feature in the toolbar but activating lock change nothing and it's still scaling non uniformly. I know there is the green gizmo but with a Wacom i found the tool bar more convenient to quickly scale. Also how can i hide the stencil since the only way i see is by reducing the opacity in the drop down menu? These features should have the possibility to be put on hotkeys since working this way is counter productive in my own opinion. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 3, 2019 Report Share Posted June 3, 2019 Are you working on Camera projection mode ? Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 4, 2019 Author Advanced Member Report Share Posted June 4, 2019 Yep working with camera projection! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 4, 2019 Report Share Posted June 4, 2019 Turn tiling on or off... The viewport will fill with the entire stencil if turned on. Right click on the centered dot and it will expose the parameters you see in the picture. Reset. This will center the stencil plus reset the stencil to full resolution. Scale uniformly using the gizmo Quote Link to comment Share on other sites More sharing options...
Advanced Member polynut Posted June 5, 2019 Author Advanced Member Report Share Posted June 5, 2019 Thank Carlo but it would be great if we could make our own shortcuts for these! Quote Link to comment Share on other sites More sharing options...
