[Solved] How to import multiple models into the library ?
seker800
Go to solution Solved by marsmotion,
Hi !
Hope this help
On 5/31/2020 at 9:39 AM, Jamie Norton said:
Thanks to @AntonTenitsky, there totally is:
There was one thing I was missing - make sure that the .obj and .png files are in the root folder that you are dropping into C:\Program Files\3DCoat-V4.9.37\VoxStamps\Objects
(of course replacing all drive and folder names for your particular situation). 3D Coat was not drilling down into the extra folder I dropped in there, so putting them all in the root folder works and this makes me very happy!
  • Carlosan changed the title to [Solved] How to import multiple models into the library ?
  • 3 years later...
  • Solution
Carlosan
marsmotion was awarded the badge 'Helpful' and 1 points.
if your working in 3dcoat 2023 or sim version, its here for windows 10x64
make a folder and drop the objs and png previews in there together
antenna_001.obj
and
etc
C:\Program Files\3DCoat-2021\UserPrefs\Models\SculptModels
