New Member MrMike Posted August 29, 2020 New Member Report Share Posted August 29, 2020 version 4.9.57 extrude + poly line selection tool only is working when object scale is exactly one. Trying to run a few tutorials on hard modeling, works in tutorial but not in this version. Am I missing something? This seems to be a recurring bug with other versions Thanks Mike Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 29, 2020 Report Share Posted August 29, 2020 Hello Try this please RMB over the layer > To Global space Sets the VoxTree objects space to be set to world space, at 0 on X, Y & Z axes. Then use any tool. Hope it help Quote Link to comment Share on other sites More sharing options...
New Member MrMike Posted August 29, 2020 Author New Member Report Share Posted August 29, 2020 no luck my flow new voxel shaping, select large sphere voxel extrude tool vertex lasso, or any of the lasso or spline selections make a shape, extrude appears on sphere res+, layer scale goes to 2x make a shape, extrude does NOT work, ( regular brushes work but none of the lasso or spline tools,) rmb over object, click to global space, looks like it does something make a shape, extrude still does not work rmb over object, increase object two times, scale indicator on layer disappears, assuming exactly 1x make a shape, extrude works again. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted August 29, 2020 Reputable Contributor Report Share Posted August 29, 2020 Are you using the old curves or the new beta ones. If you are using the new ones, I posted in the Beta forums that the voxel brushes in conjunction with the new curve tools needs testing to correct unexpected behavior which includes some of the same problems you are addressing. I have not tested the surface mode brushes. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted August 29, 2020 Reputable Contributor Report Share Posted August 29, 2020 I tested the old curves. I do confirm what is happening with the old curves. Increase the resolution of the layer and some of the poly spline tools stop working. Quote Link to comment Share on other sites More sharing options...
New Member MrMike Posted August 29, 2020 Author New Member Report Share Posted August 29, 2020 Thanks for confirming digman I installed version 4.8.15D and all spline tools are working at different object scales Quote Link to comment Share on other sites More sharing options...
Carlosan Posted September 18, 2020 Report Share Posted September 18, 2020 Fixed on version 4.9.61 Quote Link to comment Share on other sites More sharing options...
