[Bug] Bug or something else ?
rancax
Hi,
I'm starting to learn 3dcoat and have a problem.
So, due to following a tutorial from udemy - tutor uses voxel sculpting from splash menu, and selects a default figure. He demonstrates vox layer tool and starts making mask with green outline, then smooth it with shift key.
When I try to do same i'm getting weird result as seen in pic. it is not smoothing is like erasing it...ctrl works, substracts from it but shift key as if it's erasing it.... and when you apply you get weird result...
tried both on dx and gl versions... is there something that I'm missing or what
version is 4.9.72, my pc specs are i7 5820k, amd r9 380x (latest recommended drivers) and 32 gigs ram
any help?
  • Carlosan changed the title to [Bug] Bug or something else ?
6 minutes ago, philnolan3d said:
Honestly this is a bug I've dealt with ever since selections were first introduced in 3DC. Just yesterday was was frustrated by it with the Pose tool selections.
ah so I'm not the only one....thought I was only one having this problem...
well it is very strange to drag that kind of bug for so long... I hope in 2021 it will be finally fixed...
I switched from zbrush to 3dcoat because it is amazingly good, just can not stand zbrush's ui and everything related to it,,,,
