Member E.V. Posted June 28, 2022 Member Report Share Posted June 28, 2022 Hi friends, I have multiple UV sets for which the textures I already exported. Now I did some changes in one of them, and I'm not finding a way to export only this one (uv set) that was changed. Do I have to always export ALL the UV sets? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 28, 2022 Report Share Posted June 28, 2022 Hi You can export selected faces or export separate only on the full version of 3DC: Quote Link to comment Share on other sites More sharing options...
Member E.V. Posted June 28, 2022 Author Member Report Share Posted June 28, 2022 Hmm, interesting, is this menu from the full 3DCoat? I'm using Textura I don't see this (?). See my images I usually go to "file/export", then export all textures for all UV sets at once. There is another menu "textures/export/ color, roughness...", which gives us the option to choose the UV set upon export, but I'm not sure if I would have the same result, also it would require multiple clicks. 1 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 28, 2022 Report Share Posted June 28, 2022 Yes, Textura was designed only to allow Paint and Render room tasks. UV manipulation it is not possible. Quote Link to comment Share on other sites More sharing options...
Member E.V. Posted June 28, 2022 Author Member Report Share Posted June 28, 2022 Ok, I'm happy with the results anyway, thank you for clarifying! 1 Quote Link to comment Share on other sites More sharing options...
Member Kodra Posted March 2, 2023 Member Report Share Posted March 2, 2023 On 6/28/2022 at 11:41 AM, Carlosan said: Hi You can export selected faces or export separate only on the full version of 3DC: Where can you find this menu? I'm using the full 3DCoat (not textura) but I only have one export menu item, which exports all UV sets. I still can't find a way to export only one UV set. Quote Link to comment Share on other sites More sharing options...
Member MJonathan Posted March 3, 2023 Member Report Share Posted March 3, 2023 8 hours ago, Kodra said: Where can you find this menu? I'm using the full 3DCoat (not textura) but I only have one export menu item, which exports all UV sets. I still can't find a way to export only one UV set. That menu is in Modeling/Retopo Rooms! Quote Link to comment Share on other sites More sharing options...
Member Kodra Posted August 28, 2023 Member Report Share Posted August 28, 2023 On 3/3/2023 at 8:16 AM, MJonathan said: That menu is in Modeling/Retopo Rooms! And the original question was asking about how to export textures so I'm not sure how this menu helps. I'm still looking for an option to export textures from one uv set. Is it even possible? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted August 28, 2023 Report Share Posted August 28, 2023 It is possible exporting every map one by one using this menu: To allow to export specific UVset from File > Export sounds as a good feature request, please drop a line pointing to this feature request atsupport@pilgway.com Thanks Quote Link to comment Share on other sites More sharing options...
