Member Refin_ken Posted February 20, 2023 Member Share Posted February 20, 2023 Startup error In the video, I reinstalled 3d coat, I run it - I get an error how to fix it? Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 I noticed here, when starting 3d coat, it creates this folder with a strange name, if you rename this folder it does not help, 3d coat creates it again with this name Quote Link to comment Share on other sites More sharing options...
Dmitriy Nos Posted February 20, 2023 Share Posted February 20, 2023 Have you tried following the advice in the post? Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 20, 2023 Share Posted February 20, 2023 how to fix it? Install 3DC into the default installation folder C:\Program Files Link 3DC content data folder using Relocate... command Create a folder with 3DCoat data in E:\ and relocate... Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 1 hour ago, Oleg_Shapo said: Have you tried following the advice in the post? yes, I tried to completely disable the antivirus and run the setup from the admin, I also started the program itself from the admin Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 1 hour ago, Carlosan said: how to fix it? Install 3DC into the default installation folder C:\Program Files Link 3DC content data folder using Relocate... command Create a folder with 3DCoat data in E:\ and relocate... It didn't help, it doesn't start . but! For an experiment, I downloaded the old version of 3DCoat-2021-62 on a third-party site, and it works even when I downloaded it immediately to the drive E Quote Link to comment Share on other sites More sharing options...
Dmitriy Nos Posted February 20, 2023 Share Posted February 20, 2023 Is the 3dcoat folder created in Documents? Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 7 minutes ago, Oleg_Shapo said: Is the 3dcoat folder created in Documents? Да Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 24 minutes ago, Oleg_Shapo said: Is the 3dcoat folder created in Documents? Я тільки що скачав через торрент 3d coat 2022.24 і вона працює, я так зрозумів щось змінилося в нових версіях, бо 2022.24 це послідня версія яку я використовував Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 20, 2023 Share Posted February 20, 2023 If you dont use it, try uninstalling OneDrive. Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 4 minutes ago, Carlosan said: If you dont use it, try uninstalling OneDrive. okey Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 27 minutes ago, Carlosan said: If you dont use it, try uninstalling OneDrive. did not help, as I wrote above, after installing 2022.24 from the torrent, there is no error and the program starts, but the new versions do not work Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 (edited) 55 minutes ago, Carlosan said: If you dont use it, try uninstalling OneDrive. In the video with OneDrive installed, uninstalling didn't help, I checked with uninstalled OneDrive, it's the same as in the video, the new version doesn't work and the old one does Edited February 20, 2023 by Refin_ken Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 20, 2023 Share Posted February 20, 2023 There is a bug related to the second monitor. Do you have 2 monitors? if you open 3DC using the second monitor and not the main monitor it crashes. but sorry I'm out of more ideas, I hope Oleg can find the answer. Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 20, 2023 Author Member Share Posted February 20, 2023 22 minutes ago, Carlosan said: There is a bug related to the second monitor. Do you have 2 monitors? if you open 3DC using the second monitor and not the main monitor it crashes. but sorry I'm out of more ideas, I hope Oleg can find the answer. I opened it on the main monitor of the system (In the background, the old version of 3dcoat textura, which works) Quote Link to comment Share on other sites More sharing options...
Dmitriy Nos Posted February 20, 2023 Share Posted February 20, 2023 Contacted the developer. I'm waiting for an answer. Quote Link to comment Share on other sites More sharing options...
Solution SERGYI Posted February 21, 2023 Solution Share Posted February 21, 2023 On 2/20/2023 at 8:27 AM, Refin_ken said: Startup error how to fix it? "3DCoat" is trying to create a user data folder (which contains user settings and assets) inside "C:\Users\USER_NAME\OneDrive\???????\3DCoat". That is incorrect. It should create it inside "C:\Users\USER_NAME\Documents\3DCoat". To workaround this problem: Start > start typing "Edit the system environment variables" > Environment Variables... > System variables > New... > Variable name: COAT_USER_PATH Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside) 2 Quote Link to comment Share on other sites More sharing options...
Member Refin_ken Posted February 21, 2023 Author Member Share Posted February 21, 2023 2 hours ago, SERGYI said: "3DCoat" is trying to create a user data folder (which contains user settings and assets) inside "C:\Users\USER_NAME\OneDrive\???????\3DCoat". That is incorrect. It should create it inside "C:\Users\USER_NAME\Documents\3DCoat". To workaround this problem: Start > start typing "Edit the system environment variables" > Environment Variables... > System variables > New... > Variable name: COAT_USER_PATH Variable value: C:\Users\USER_NAME\Documents\My3DCoatData (specify your user name inside) Yes! It helped! thank you very much 2 Quote Link to comment Share on other sites More sharing options...
