Advanced Member zf3d Posted July 18, 2023 Advanced Member Report Share Posted July 18, 2023 HMC Voice Command for 3D Coat 2022 & 2023 For example, for a brush command, how do I add my own voice and then control this command? I see shortcut keys, but I don't know how to input them? Add a custom control Quote Link to comment Share on other sites More sharing options...
Advanced Member zf3d Posted July 20, 2023 Author Advanced Member Report Share Posted July 20, 2023 +1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 20, 2023 Reputable Contributor Report Share Posted July 20, 2023 You cannot (currently) add your own voice. It uses the default voices in Windows (10-11), Male or Female. This is not a major issue because you only hear it telling you that it is listening or in sleep mode. Everything else is just you speaking to the software, telling it what you want it to fetch for you. Think of it this way....it's like an assistant nurse or doctor in the surgery room, and you are the surgeon. Instead of you having to stop and dig through a tray full of surgical tools/instruments (each time to need to switch to something different), you just keep working and say what you need...then your assistant puts the new tool in your hand so you can keep working without interruption. Quote Link to comment Share on other sites More sharing options...
Advanced Member zf3d Posted July 21, 2023 Author Advanced Member Report Share Posted July 21, 2023 I have a general understanding, so currently it is not useful for foreigners, such as Chinese people. If one day, you can customize the sound and functions, it would be great. Currently, I use the operation of spaces+123456, which is very fast Quote Link to comment Share on other sites More sharing options...
Member Genie Voice Command Posted February 9 Member Report Share Posted February 9 This post was recognized by Carlosan! Genie Voice Command was awarded the badge 'Great Support' and 1 points. On 7/20/2023 at 5:34 PM, zf3d said: I have a general understanding, so currently it is not useful for foreigners, such as Chinese people. If one day, you can customize the sound and functions, it would be great. Currently, I use the operation of spaces+123456, which is very fast Hi! I am the owner and creator of HMC for 3DCoat. It used to be named Genie Voice Command hence my name. In the future if all goes well I hope to support other languages like Chinese, French, Japanese, Italian and so on. I like to thank you for posting an image of the HMC UI. I was not aware that the font for the UI text could be different than the one I see on my own computer. I will have to look into how to set the font so all users see the UI the same. Different fonts have different spacings and obviously will mess up the readability of the the UI. There is a new trial version out and it now works with 3DCoat 2024:https://hmccabe.com/download/3d-coat-4-9-trial-version-of-genie-voice-command/ Thanks for trying my program out and thanks for the feedback. 1 Quote Link to comment Share on other sites More sharing options...
