Advanced Member pieralessi Posted October 4, 2023 Advanced Member Share Posted October 4, 2023 Hi, I'm trying to follow up the steps on the youtube official video but sometimes works, sometimes no, I made all steps you suggested me in the YT replies but works in one new file but in this every time make something rare or no works. I put the line but the handles disappeared, was working the undo command for start again but now works only pressing escape. when I press enter no results, no image. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 4, 2023 Share Posted October 4, 2023 Image tool is for Splines painting Are you following this steps ? Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 4, 2023 Author Advanced Member Share Posted October 4, 2023 I'll try it, are other official video. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 6, 2023 Reputable Contributor Share Posted October 6, 2023 On 10/4/2023 at 7:25 PM, pieralessi said: I'll try it, are other official video. Pier, what OS are you using? Windows, MAC, Linux? Could you possibly record a screen capture of these things happening? Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 7, 2023 Author Advanced Member Share Posted October 7, 2023 Windows 10 bandicam 2023-10-07 05-53-14-924.mp4 Hi, sometimes the picture appears, sometimes not like now, I tried with a new layer but nothing, before with Undo I went back and tried again, the image appeared but with a color that I had managed to solve by changing it to white. Now I return only with scape but it is still not working. I had tried it on another document with a ball of material and it had worked. With the original document, if I redo the mapping, sometimes it works and sometimes it doesn't. Thanks Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 11, 2023 Author Advanced Member Share Posted October 11, 2023 No solution? bandicam 2023-10-07 05-53-14-924.mp4 Hi, sometimes the picture appears, sometimes not like now, I tried with a new layer but nothing, before with Undo I went back and tried again, the image appeared but with a color that I had managed to solve by changing it to white. Now I return only with scape but it is still not working. I had tried it on another document with a ball of material and it had worked. With the original document, if I redo the mapping, sometimes it works and sometimes it doesn't. Thanks Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2023 Share Posted October 11, 2023 Try settings this values Quote Link to comment Share on other sites More sharing options...
Advanced Member pieralessi Posted October 11, 2023 Author Advanced Member Share Posted October 11, 2023 Did I miss some detail? I was using and checking all the Tool options but... Quote Link to comment Share on other sites More sharing options...
Carlosan Posted October 11, 2023 Share Posted October 11, 2023 This ones: Number of tiles = 1 Falloff = 0.265 Extrusion = 1 Ignore back faces = on depth/width modulator = 1 Color modulator = 2 Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution pieralessi Posted October 11, 2023 Author Advanced Member Solution Share Posted October 11, 2023 Finally done, it is really impossible to guess the values of each element understanding that these are somewhat abstract, especially for those who do not have experience with the program. I was trying to test values before but I would have to do countless permutations until I found the result, this is not discussed much in the videos. I was trying to create a repetition of the picture with a circle but it was difficult for me to make it a perfect circle, even with the "circle" option in the tool options. I tried it with the drawing tools circle and it didn't work. I know I'm asking too much but 3D Coat, although it has lots of (old) tutorials, does not have an orderly teaching method, not all tools have F1 search, nor a visual explanation on the page, just text that is not understood. This consumes a lot of time for me to have to venture out and try values and options that are not intuitive at all. Thank you 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted October 12, 2023 Reputable Contributor Share Posted October 12, 2023 This post was recognized by Carlosan! AbnRanger was awarded the badge 'Helpful' and 1 points. On 10/11/2023 at 12:33 PM, pieralessi said: Finally done, it is really impossible to guess the values of each element understanding that these are somewhat abstract, especially for those who do not have experience with the program. I was trying to test values before but I would have to do countless permutations until I found the result, this is not discussed much in the videos. I was trying to create a repetition of the picture with a circle but it was difficult for me to make it a perfect circle, even with the "circle" option in the tool options. I tried it with the drawing tools circle and it didn't work. I know I'm asking too much but 3D Coat, although it has lots of (old) tutorials, does not have an orderly teaching method, not all tools have F1 search, nor a visual explanation on the page, just text that is not understood. This consumes a lot of time for me to have to venture out and try values and options that are not intuitive at all. Thank you If you are placing points and don't actually see the circles representing them, that indicates something is really skewed with scale/width values. Setting them back to the defaults can help in such a situation. Quote Link to comment Share on other sites More sharing options...
