New Member Hansi Posted December 21, 2023 New Member Report Share Posted December 21, 2023 Hi there, we are using 3D-Coat for quite a while now and are usually very happy. But now I have a super urgent topic. I retopologize a MetaHuman Mesh to a 3D scan... When using symmetry this unfortunately changes the topology of the mesh ... But only if I apply the symmetry... If I export the Mesh without applying the symmetry, the vertex count is still the correct one. Can I switch that behaviour off ? For the MetaHuman pipeline this is very bad :-/ Best regards, Hansi PS: the super urgent part is that I have a presentation tomorrow and needed to retopologize something Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted December 21, 2023 Report Share Posted December 21, 2023 I'm not exactly sure of the problem but perhaps try going into Mesh at the top and uncheck Virtual Mirror Mode before you apply symmetry. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 29, 2023 Reputable Contributor Report Share Posted December 29, 2023 On 12/21/2023 at 3:15 AM, Hansi said: Hi there, we are using 3D-Coat for quite a while now and are usually very happy. But now I have a super urgent topic. I retopologize a MetaHuman Mesh to a 3D scan... When using symmetry this unfortunately changes the topology of the mesh ... But only if I apply the symmetry... If I export the Mesh without applying the symmetry, the vertex count is still the correct one. Can I switch that behaviour off ? For the MetaHuman pipeline this is very bad :-/ Best regards, Hansi PS: the super urgent part is that I have a presentation tomorrow and needed to retopologize something When you Retopologize, you are building a new mesh, so how could the vertex count remain the same (the same as what..the high poly/voxel object)? I don't quite understand what it is exactly that you are trying to accomplish. Perhaps a screen recording would help members or staff diagnose the issue? Quote Link to comment Share on other sites More sharing options...
