Member andreamelo Posted March 16 Member Report Share Posted March 16 I installed V 2024.14 on windows 11, the characters and icons are tiny (I have to use the magnifying glass to see them), I changed everything on the Themes: I went from Auto to large, I went to font size up to 20, when I press Apply 3dc always crashes and I have to restart it. I didn't solve it even by changing the properties for HD screens on Windows. this is not possible, it is absurd, there are always too many problems, I have already wasted hours of work uselessly and I have lost patience. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 16 Reputable Contributor Report Share Posted March 16 This post was recognized by Carlosan! digman was awarded the badge 'Helpful' and 1 points. Windows version---2024.14. Windows 11 There is "No Crashing" switching Fonts on my end. The Last Resort: In the edit menu---Choose reset to default settings. The picture shows the next screen to appear. Keep all boxes selected. 3DC will restart and then try changing your font size. I do not know your setup so of course you might lose some user settings. ------------------------------------------------------------------------------------- Before trying the above, you could try just deleting the Options.xml. Make sure 3DC is closed when you do this. 3DC will auto create a new options.xml file when reopening 3DC. Then try changing your font size. Location of options.xml file shown in picture. Quote Link to comment Share on other sites More sharing options...
Member andreamelo Posted March 17 Author Member Report Share Posted March 17 Dell PC 15 9570 RAm 32gb win11 , 3dcoat 2024.14; after a long wait (20 minutes) I managed to enter font value 18 and ( and medium ) the result is the one in the attached photo. Now everything is too big and I can't access the preferences menu at the top left. I also reinstalled 3dcoat 2024.14 but everything remains the same. I deleted Options (3dcoat closed) but everything remains unchanged, I don't know what to do anymore. tell me please. Thank you Quote Link to comment Share on other sites More sharing options...
Member Solution andreamelo Posted March 17 Author Member Solution Report Share Posted March 17 Hi, I solved it by renaming the User/document/3dcoat folder, and he recreated it with default settings and font too small (it doesn't reset by only deleting Option file from preferences), then I inserted font_size medium and font with value 10 in Preferences/theme and after many minutes finally everything appears correct. Thank you :-) 1 Quote Link to comment Share on other sites More sharing options...
Member andreamelo Posted March 26 Author Member Report Share Posted March 26 I don't know what to do anymore, if I right click on the sculpt tree a gray screen appears and I don't see the options, if I'm in voxel mode everything is clearly visible (why?). I have size 10 fonts, if I insert size 9 everything appears perfectly, this is a BUG please fix it; I'm old and wear glasses, I can't work with small dimensions, and in any case I use many other software and only with 3dcoat do I always have viewing problems Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 26 Report Share Posted March 26 Edit > Preferences > Theme Grey-out Background w/... is turned OFF ? Quote Link to comment Share on other sites More sharing options...
