Advanced Member Scott Padbury Posted September 15, 2009 Advanced Member Report Share Posted September 15, 2009 Okay, I retopoed to get the shirt. How do I get the shirt to sculpt and paint? Do I have to retop again? I'am also doing a pair of pants the same way, I noticed that it came into voxel with the shirt which I have already done.How do I just get the pants only? Do I have to delete the shirt topo? Any help would be great thanks? Also still having problems around the face area all openings are closed. Quote Link to comment Share on other sites More sharing options...
Taros Posted September 16, 2009 Report Share Posted September 16, 2009 I don't really understand your question. What do like to do? To skulpt with voxels, you don't need to retopo something. To paint you need a mesh with uvw coordinates. In this case you need to retopo a finished model and give it texture coordinates. Be creative Chris Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted September 16, 2009 Author Advanced Member Report Share Posted September 16, 2009 I don't really understand your question.What do like to do? To skulpt with voxels, you don't need to retopo something. To paint you need a mesh with uvw coordinates. In this case you need to retopo a finished model and give it texture coordinates. Be creative Chris Chris, well right now it is in Voxels as you can see, I want to go from there to paint and sculpt. You do need to retopo if you are making a new object to sculpt such as a shirt which i just did. All I had was the body. Ok, so I do need to retopo the shirt as you say. All I want is the shirt to sculpt and paint on so how do I get it from voxels to there was my question ? Thanks Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted September 16, 2009 Contributor Report Share Posted September 16, 2009 Chris,well right now it is in Voxels as you can see, I want to go from there to paint and sculpt. You do need to retopo if you are making a new object to sculpt such as a shirt which i just did. All I had was the body. Ok, so I do need to retopo the shirt as you say. All I want is the shirt to sculpt and paint on so how do I get it from voxels to there was my question ? Thanks You can "Quadrangulate" the "shirt" in Voxel mode (if it;s a seperate volume) and export it for Per Pixel or Micro Vertex painting. This will give the object 3DC's best guess at a new topology. Quote Link to comment Share on other sites More sharing options...
Advanced Member Scott Padbury Posted September 22, 2009 Author Advanced Member Report Share Posted September 22, 2009 You can "Quadrangulate" the "shirt" in Voxel mode (if it;s a seperate volume) and export it for Per Pixel or Micro Vertex painting. This will give the object 3DC's best guess at a new topology. I will try that thanks.. Quote Link to comment Share on other sites More sharing options...
