Advanced Member Juan Carlos Montes Posted August 28, 2007 Advanced Member Report Share Posted August 28, 2007 Here is some tests with the program , I really love the software I going to play more with the software to enter the contest, But I have to register to export the textures no? Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted August 28, 2007 Author Advanced Member Report Share Posted August 28, 2007 Here are a sculpt done all in 3d brush ,nice! I staring to know the software a bit more Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 5, 2007 Author Advanced Member Report Share Posted October 5, 2007 More play,I have my Pro version of 3d brush :lol: , awesome Program, I did this test like 40 min am going to re make the textures again an rear for more Frog references to make the skin more real. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 6, 2007 Report Share Posted October 6, 2007 Cool! Especially for 40 min! Only eyes should be lustred get better effect. Can I use your images for the gallery? Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 8, 2007 Author Advanced Member Report Share Posted October 8, 2007 Cool! Especially for 40 min! Only eyes should be lustred get better effect. Can I use your images for the gallery? Yes You can use it , here is a more elaborated version of the frog Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 8, 2007 Author Advanced Member Report Share Posted October 8, 2007 Here is a Render in Carrara 6 I export the Displace map texture as BMP an re save it in TGA because carrara doesn't read it, Am going to try the 32bit image in XSI. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 8, 2007 Report Share Posted October 8, 2007 Very good! May be there is some displacement height scale coefficient in Carrara. It is better to increase this coefficient to get better result (meke frog sligtly more bumpy). Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 8, 2007 Author Advanced Member Report Share Posted October 8, 2007 I accidentally Paint some bumps in Layer 0 and when you export the depth it doesn't read that layer, there is a way to move that information to another layer? when I right click that layer I get only (new layer) Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 8, 2007 Report Share Posted October 8, 2007 It is pity, but layer 0 is background layer (like in Photoshop), so displacement is counted like distance from level 0. So it is better to draw small details in other layers. Now there is no way to move bump from layer 0 to another layers because layer 0 contains absolute coordinates and another layers contain offset from layer 0. But I have understood the problem and in one of the next versions I will add option "separate level on low and high frequency parts". Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 8, 2007 Author Advanced Member Report Share Posted October 8, 2007 It is pity, but layer 0 is background layer (like in Photoshop), so displacement is counted like distance from level 0. So it is better to draw small details in other layers. Now there is no way to move bump from layer 0 to another layers because layer 0 contains absolute coordinates and another layers contain offset from layer 0. But I have understood the problem and in one of the next versions I will add option "separate level on low and high frequency parts". Ma bey i have to export all the textures and Depth and import the obj again. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 8, 2007 Report Share Posted October 8, 2007 Yes, it will help you to set background layer to initial state. Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 9, 2007 Author Advanced Member Report Share Posted October 9, 2007 I import all to XSI because I can get more detail and subdivide the model in level 5 even more Am going to add SSS to the model and make the eyes in the nex version. Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 13, 2007 Author Advanced Member Report Share Posted October 13, 2007 Another render, still playing with the SSS. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 13, 2007 Report Share Posted October 13, 2007 Cool! it becomes more bold! Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 17, 2007 Author Advanced Member Report Share Posted October 17, 2007 I tested the 16bit Image an works great Here is my new model a bear,I start to adding details. I have a piece of the model with artifacts, any option to fix that? Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 17, 2007 Report Share Posted October 17, 2007 Looks cool! About artifact: may be it is because of not good uv-mapping in this place? Can you show how this part looks in uv-map? Also I think these artifacts are only during the edit process (render I think will be good). Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 17, 2007 Author Advanced Member Report Share Posted October 17, 2007 Here is th uv layout. I use silo2 unwrap for the Uv. Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 17, 2007 Author Advanced Member Report Share Posted October 17, 2007 You was right It was the Uv map, I unwrap the piece again and I fix the problem. Thanks Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted October 28, 2007 Author Advanced Member Report Share Posted October 28, 2007 Here is my Dirty Bear again, still in progress. Administrator soon you are going to have a new image for the gallery. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted October 28, 2007 Report Share Posted October 28, 2007 O! It is really cool! Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted November 6, 2007 Author Advanced Member Report Share Posted November 6, 2007 Here is a render in Xsi 6 Using normal maps, Administrator u can add this one to the gallery , Am going to tray the same process in Carrara 6 using Baker Plugin 1 Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted November 6, 2007 Report Share Posted November 6, 2007 Very good! Very impressive! Thank you so much!!! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted November 6, 2007 Report Share Posted November 6, 2007 Juan, do you know that you was the first who have purchased 3D-Brush? It was month ago. It was good beginning. Today already 80 peoples have purchased 3DB. I think you also have a good contribution in it. Thank you! It will allow us to develop 3DB more and more. Quote Link to comment Share on other sites More sharing options...
Advanced Member Juan Carlos Montes Posted November 6, 2007 Author Advanced Member Report Share Posted November 6, 2007 Wow! Im the first one, am very glad . Thanks to you for bring us this great and easy to use aplication, I fall in love with this tool at the first try am happy with the product and be one of the first users. I know this Program is going to be more an more popular. Congratulations to all the team. Quote Link to comment Share on other sites More sharing options...
Advanced Member wailingmonkey Posted November 9, 2007 Advanced Member Report Share Posted November 9, 2007 Nice work, Juan Carlos Montes. I'd be curious to see your render tree, if you've got a chance. cheers. wailingmonkey Quote Link to comment Share on other sites More sharing options...
New Member esha Posted November 10, 2007 New Member Report Share Posted November 10, 2007 Wow! I love that frog! *ggg* Quote Link to comment Share on other sites More sharing options...
