Member Jack Posted May 8, 2011 Member Report Share Posted May 8, 2011 Hi, I'm trying to learn to use 3d coat 3.5. I need to make a mask for a voxel object. I've read the instructions. When I go into surface mode a "Freeze" tool appears. Is this the tool that the manual describes as "SfFreeze?" I don't have a "SfFreeze." Anyway, when I try to paint a mask with the Freeze tool activated nothing happens. The video tutorial mentioned something about adjusting intensity for the freeze, but I can't find any intensity settings. Am I doing something wrong? Has anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
Javis Posted May 9, 2011 Report Share Posted May 9, 2011 Hi there! SfFreeze has been renamed to Freeze in surface mode. I'll let the person who now does the manual know about the manual needing a change. Thanks for the heads up. To control the intensity of the Freeze tool, and some other tools in 3DC, you directly manipulate it with the RMB over and object and then drag up/down. The red/blue/green line in the center of the yellow brush circle should move correspondingly. This is your intensity. The bottom of the circle is 0%, the top 100%. Hope this helps, -Javis Quote Link to comment Share on other sites More sharing options...
Member Jack Posted May 9, 2011 Author Member Report Share Posted May 9, 2011 Thanks. That is working. Quote Link to comment Share on other sites More sharing options...
Javis Posted May 9, 2011 Report Share Posted May 9, 2011 Excellent news. Don't hesitate to post more questions when/if you have them! Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 16, 2012 Report Share Posted June 16, 2012 sorry i revive this old post but... control the intensity of the Freeze tool works... where can see the amount of intensity ? Freeze operations Hot key not working here, please could any1 check it ? TY! Toggle freeze view (ALT+F) nothing Unfreeze all (CTRL+D) ok Invert freeze/selection (CTRL+SHIFT+I) ok Show/hide freeze (CTRL+F) nope Smooth freezing (CTRL+NUM*) hmmm no Expand frozen area (CTRL+NUM+) no Contract frozen area (CTRL+NUM–) no Freeze border (CTRL+NUM/) no any help is welcome u using last beta Quote Link to comment Share on other sites More sharing options...
