Advanced Member ggaliens Posted December 18, 2011 Advanced Member Report Share Posted December 18, 2011 3.5 to 3.7 problem. (Nothing works with VOX) As soon as I go to build or smooth or clay tool ... The tool is 100% destructive. Seems to remove all VOX under the tool cursor. Restarted 3DCoat several time. Tried different models. Tried Sphere primitive (does not even show up). I think I'll revert to 3.5 as a sanity check. Any other advise is appreciated. Quote Link to comment Share on other sites More sharing options...
Advanced Member ggaliens Posted December 18, 2011 Author Advanced Member Report Share Posted December 18, 2011 Uh ... YUK. Tried very latest 3.7 something B. No luck. Should we not be able to get older versions if we are paranoid. I don't know what would have happened here. Vox primitives spheres, CUBE, Cylinder ... they don't show up as VOX. EDIT : Also ... a bit more info. I've been using 3.7 almost exclusively for rendering and turn-table renders. All of that work. It seems like just the scuplting in VOX room is not working. Quote Link to comment Share on other sites More sharing options...
Moderator Daniel Posted December 19, 2011 Moderator Report Share Posted December 19, 2011 Tried on WinXP 32-bit, 3D-Coat 3.7.01B (DX) - works fine! Please, tell your specs, and I'll report it as a bug Quote Link to comment Share on other sites More sharing options...
Advanced Member ggaliens Posted December 20, 2011 Author Advanced Member Report Share Posted December 20, 2011 I wish I had time to do some more footwork in this ... Andrew asked me to get new NVIDIA drivers. And despite it being a new machine ... with a NVIDIA with CUDA sticker on it, and with factory software and settings, 3DCoat didn't work. I think the card was a GeForce 9100 class card. It is an HP Pavilion Feb 2010 vintage. 8GB Ram and 64 bit Windows 7. After upgrading to latest NVidia drivers for that card ... all was well. Not too crazy ... but I did run around in circles until Andraw suggested all I needed was latest NVidia driver and 3DCoat 3.7 I remember more of a software stack for 3DCOat from days gone by including a separate CUDA download. I'm glad it ended up being simple enough to fix and Thanks to Andrew for prompt reply to my message. I consider this case as closed. Quote Link to comment Share on other sites More sharing options...
Member Grooveholmes Posted December 20, 2011 Member Report Share Posted December 20, 2011 I've had the same issues for several frustrating days. I rolled back to 3.5 yesterday and the problem went away. Quote Link to comment Share on other sites More sharing options...
Javis Posted December 20, 2011 Report Share Posted December 20, 2011 Andrew asked me to get new NVIDIA drivers. And despite it being a new machine ... with a NVIDIA with CUDA sticker on it, and with factory software and settings, 3DCoat didn't work. I think the card was a GeForce 9100 class card. It is an HP Pavilion Feb 2010 vintage. 8GB Ram and 64 bit Windows 7. After upgrading to latest NVidia drivers for that card ... all was well. Not too crazy ... but I did run around in circles until Andraw suggested all I needed was latest NVidia driver and 3DCoat 3.7 I remember more of a software stack for 3DCOat from days gone by including a separate CUDA download. I'm glad it ended up being simple enough to fix and Thanks to Andrew for prompt reply to my message. I consider this case as closed. Glad to hear that was the case. Quote Link to comment Share on other sites More sharing options...
Member Grooveholmes Posted January 4, 2012 Member Report Share Posted January 4, 2012 I've got the latest drivers from nvidia, still seeing the same issue. Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted January 4, 2012 Report Share Posted January 4, 2012 I've got the latest drivers from nvidia, still seeing the same issue. Was you sending crash reports? If you will help me identify them (send me e-mail to support) by e-mail or other - I may find reason and help. Quote Link to comment Share on other sites More sharing options...
