Member shokan Posted February 19, 2012 Member Report Share Posted February 19, 2012 Been a long time since I've been here and I can see 3DCoat has come a long way since 3D-Brush! Is it possible to make a section of fisherman's netting using 3DC? It will be viewed from a distance, so the twist texture to the individual strands is not necessary. Hopefully it will not be a large polygon count. Thanks. Quote Link to comment Share on other sites More sharing options...
Advanced Member johnnycore Posted February 19, 2012 Advanced Member Report Share Posted February 19, 2012 It should be possible to create a model like this, you could model one section as a perfect square using the curve tool and instance it a gazillion times using the instancer until you got a large net. Technically they should be able to connect with eachother, if you model it properley it should not be a problem. Afterwards you could merge em to one voxel volume, use the move tool to make it look less perfect. If polycount is important and its being viewed from a distance, I recommend using a texture + alpha map, if im correct there should be a free tileable fishnet mask in one of these resources from the 3DCoat download page: =2"]http://3d-coat.com/download/3dcpack/file-list/?tx_neofileshare_pi4[cat]=2 Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted February 20, 2012 Report Share Posted February 20, 2012 You could also use the Curves tool to make it. Or use Curves in conjunction with the above idea Quote Link to comment Share on other sites More sharing options...
Reputable Contributor Solution AbnRanger Posted February 20, 2012 Reputable Contributor Solution Report Share Posted February 20, 2012 You do realize that you can invert that image in Photoshop (so the mesh is white and the background is black), save that version, then use it with the Logo tool. In just a couple of clicks you've got a grid of fishnet. You will probably want to click SMOOTH ALL (at the bottom of the tools pallet) a few times, so it will round the edges for you. If needed, you can also deform the net with the Pose Tool (recommend the new Freeform deformation cage). 1 Quote Link to comment Share on other sites More sharing options...
