Advanced Member TLE Posted March 6, 2012 Advanced Member Report Share Posted March 6, 2012 i merged in a box without voxelized it. the box has very low plygon number. i used general brush and clicked on an edge to sculpt. the tool "smooth" out the edge before adding detail. how can i add detail to the box without changing the shape of the box? other way around this is increase the polygon of the box to very high before using the tool. However, it will change the whole purpose of the idea that can add very high detail mesh on top of very low res polygon. Thanks Quote Link to comment Share on other sites More sharing options...
Psmith Posted March 6, 2012 Report Share Posted March 6, 2012 It depends on what you mean, exactly, by the word "detail". If you want to maintain all of the characteristics of the original, imported box - then decorate the box with surface detail - you should import your object for "Per-pixel painting", and use the Paint Room tools to add Color, Specularity and Bump (mild displacement). If you need much larger kinds of "detail" - try importing your mesh into "Voxel Surface Mode" where more extreme detail (more displacement) can be added - then merge the result into the Paint Room for further, finer detailing. To import your mesh into "Surface Mode" - first open an empty Voxel scene, click the small cube icon to the left of the primary Layer in the "Layers panel", and select "Merge" from the "Objects" category of the "Tool Panel" on the left of the interface. Greg Smith Quote Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted March 6, 2012 Advanced Member Report Share Posted March 6, 2012 to add detail using general brush: set all values to zero except refine steps and detail, set detail to 3 per exemple, it adds very fine polygons without altering the shape of the cube. Quote Link to comment Share on other sites More sharing options...
Advanced Member The Candy-floss Kid Posted March 7, 2012 Advanced Member Report Share Posted March 7, 2012 i merged in a box without voxelized it. the box has very low plygon number. i used general brush and clicked on an edge to sculpt. the tool "smooth" out the edge before adding detail. how can i add detail to the box without changing the shape of the box? other way around this is increase the polygon of the box to very high before using the tool. However, it will change the whole purpose of the idea that can add very high detail mesh on top of very low res polygon. Thanks Try first protecting the edges of the box with the freeze tool to paint a protecting mask - or reduce your brush size when you paint up against the edge. Better still follow the gender unspecified advice of Spacepainter's great tip. Quote Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted March 8, 2012 Advanced Member Report Share Posted March 8, 2012 My english is not sufficient to answer this sarcasm(?) I am male if you care. At my level of consiousness just trying to contribute to this great software. Quote Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted March 8, 2012 Advanced Member Report Share Posted March 8, 2012 What's next joking about nationality? Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted March 8, 2012 Contributor Report Share Posted March 8, 2012 Ah come on, mate! "Not telling" invites curiousity and not necessarily of a prurient nature. And joking about nationality is not politically correct, as we all know. But making a stab at it in an international forum like this one only if it gets it's own forum. Quote Link to comment Share on other sites More sharing options...
Advanced Member spacepainter Posted March 9, 2012 Advanced Member Report Share Posted March 9, 2012 I like to anonymously exhibit my sillyness so not telling my nationality And not fond of filling out forms in general. Like the general brush settings :- p Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted March 9, 2012 Contributor Report Share Posted March 9, 2012 Commendable reticence! Quote Link to comment Share on other sites More sharing options...
