I'm looking for all the information I can get on the Blending Tab in the Paint Room
  • Please log in to reply
10 replies to this topic
#1 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,268 posts
  • Gender:Male
Posted 14 July 2012 - 08:23 PM
I'm busy trying to get patches of texture, made from Normal Map relief and Diffuse Color to blend smoothly. I've done some searches on this and I'm playing with falloff settings and using the Paint tool with Shift so smooth out the edges of each patch of painted texture. I'm also experimenting with painting individual patches on their own layers with varying settings like Overlay or Multiply and then merging them later.
All these tactics are yielding varying degrees of success.
I do wish there was more manual documentation on them.
One potential asset in the Paint Room particularly piqued my interest; the Blending Tab.
If anyone has any info, documentation or instructions on how to utilize this tab could you please share it with us?
The manual passage is very brief and doesn't really say much.
#2 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,493 posts
  • Gender:Male
Posted 14 July 2012 - 10:22 PM
A little more workflow information would be helpful on the blend smoothing problem.
Are you using a material (under the material tab) to paint your normal map for height (details) and diffuse map at the same time? Are you painting using the texture uv editor?
When you have additive paint turned off under your depth icon, it will only work on one layer at a time. If you switch to another layer and continue painting depth it will overlap. Which is something I think I will put under a feature request to change. When additive depth painting is turned off it should blend and not overlap other layers just like it does on one layer.
#3 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,268 posts
  • Gender:Male
Posted 15 July 2012 - 03:30 AM
Well part of it has to do with the depth setting...If you're using a material Targa and the depth is set to say 52 and then you change to another very similar Targa material but it's not quite the same setting it's like you're forced to test back and forth to get it to the same depth setting (that may be completely different as a numerical parameter, say 32 or 75)
Specifically though I'd really like complete documentation on that Blending Tab. Obviously someone put a few days of work into designing it and inserted it there. It'd be nice to see what it was fully intended to do and how its parameters work.
#4 TimmyZDesign
TimmyZDesign
    Apprentice
  • PipPipPip
  • 935 posts
  • Gender:Male
  • Interests:3D Generalist
Posted 15 July 2012 - 04:16 AM
Yes, I was also wondering about that tab. I couldn't figure out what it does...
Intel Xeon W3570 (4 core @ 3.2GHz) 6 GB RAM
Nvidia Quadro k4000 (3GB GPU memory, CUDA, OpenGL)
Windows Vista Professional 64-bit
1st display is Wacom Cintiq 21UX (2nd Gen) (1600 x 1200)
2nd display is ASUS VE245H (1920 x 1080)
#5 AbnRanger
AbnRanger
    Master
  • PipPipPipPipPipPip
  • 6,261 posts
  • Gender:Male
Posted 15 July 2012 - 05:28 AM
The Blending panel is more like a Layer Attributes panel. You can adjust the depth level, contrast, spec level, etc. per layer
#6 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,493 posts
  • Gender:Male
Posted 15 July 2012 - 08:06 AM
Ok, I got a solution to the blending problem using similar but different material images. You could call it a workaround but really it is quite useful.
This is for PPP but you should be able to use on MV too.
Solution:
Paint only your color map, no depth using the 2 or more material images. I normally use some brush alpha falloff to help with blending color textures...
Export your diffuse color map as a TIF file.
Now just Import the diffuse color as a "0" level is grey base displacement map, Yes, you can import displacements maps into PPP. You do not need to convert the color texture to a greyscale. You could of course if you want to and you would have more options in the importing but it's not necessary.
Next just use the depth parameters in the layers tab to increase the depth of your displacement to what you want.
In the first picture I used two different material images to paint the color map
Followed the above method
Increased the depth 500% after importing to increase the depth to what I wanted...
The displacement will be added to the normal map...
Second picture is the displacement in relief view only.
It's low quality as it was only a1024 map.
I hope you find this useful and maybe it will get the result you want.... B)
#7 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,268 posts
  • Gender:Male
Posted 15 July 2012 - 03:52 PM
Solution:
Hey great minds think alike. I was sort of thinking of this solution yesterday. And you could take your diffuse map into Photoshop for some really detailed blending
#8 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,268 posts
  • Gender:Male
Posted 15 July 2012 - 04:00 PM
Thank you.
so maybe the solution is to just paint the separate patches as separate layers then blend them using the Blending Panel controls.
#9 AbnRanger
AbnRanger
    Master
  • 6,261 posts
  • Gender:Male
Posted 15 July 2012 - 05:19 PM
Thank you.
You would use the Clone Stamp tool in Photoshop to Blend between parts of an image...no? You have that in 3DC. Same icon as in PS. Except the hotkey to sample some pixels, is CTRL instead of ALT (as it is in PS).
#10 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,268 posts
  • Gender:Male
Posted 16 July 2012 - 01:40 AM
Works well, thanks.
#11 AbnRanger
AbnRanger
    Master
  • 6,261 posts
  • Gender:Male
Posted 16 July 2012 - 06:52 PM
Works well, thanks.
No problem. Hope that solves your issue.
