Posts
503 -
Joined
Last visited
Calendar
Gallery
Everything posted by Daniel
Sure, why not! General idea is to keep resolution as low as possible, and increase it locally (performed automatically with LC). All the rest depend on your hardware
I would say: 1. Start with Voxels -> base shape -> rough details 2. Live clay -> fine tunning
I couldn't (at least yesterday) I would like to see your work made that way - very curious!
Hi! See attach
Здравствуйте, скоро получите ответ. Спасибо!
- да, вот примерный пример Всё делается с помощью инструмента Curves
you miss one of these steps under Retopo menu (arrows point to the most used)
Hey, welcome aboard! Hope you'll like the community! With your spec I wouldn't worry about anything (though everything has its limits) Anyway you have enough time to make something "heavy" in order to see how it goes
Да вроде как есть уже давно, если я правильно понял о чем речь! Еще неизвестно у кого она первая появилась
Здравствуйте, чтобы диаметр был 61, надо радиус поставить 30,5 а вот будут это метры или миллиметры надо выставить во вкладке Voxels->Define measurement units (верхние менюшки) также есть инструмент Measure в воксельной комнате, можно им
Yep DX problem! Reported to Andrew about GTX 460... i can't tell much as I don't have other graphic card to compare (I had 9800GT, but I don't remeber its performance already). It works OK for me. Sorry, can't help
- 17 replies
- DOF plane
- retopo mesh
(and 4 more)
Tagged with:
Considering the wireframe problem in Render room... I don't have one neither in Persp nor Ortho mode (see attach) I'm on Win7 Pro 64-bit using v4 BETA6B 64bit CUDA GL. My graphic card is GTX 460 SE (driver version 301.42) BF culling is used to see double-sided "flat" polygons or not-closed meshes
- 17 replies
- DOF plane
- retopo mesh
(and 4 more)
Tagged with:
Welcome aboard, Sven! Glad to have you with us
I suppose not for now
- This 2 prog can be the complete graphic pipeline for my needs or you have other hints? - Absolutely!
Blender import / 3D Coat multiple Objects problem
Daniel replied to Gian-Reto's topic in General 3DCoat
Is export settings for normal map set to Maya/Blender? (I guess, yes) -
Try to select everything and change to Flat and then back to Smooth -
Did you check normals direction in Blender? -
3D-Coat uses smooth shading until you tell it to use auto-smoothing groups with defined angle of edge splitting. So if you don't use Auto-smoothing groups in 3D-Coat, then all you need to do is to change shading in Blender from Flat to Smooth (without any manual edge splitting). Anyway some screenshots will help a lot (as always!) -
Why do closed objects perform better for painting than open ones?
Daniel replied to popwfx's topic in General 3DCoat
In your case, when you load your solid model, the top part of it (the one that you need) covers only the fourth part of the UV texture! That's why you experience better performance with solid one! -
Welcome aboard Walker!
