Member Dennis Nikolaidis Posted June 5, 2016 Member Report Share Posted June 5, 2016 Many times I'll find myself in a situation that while doing retopology, some vertices will snap on the back of the model instead of the side I'm editing. First of all I wanted to ask if there is a way to avoid this misshap, and second I was wondering if there is a way to move those vertices back where I want (move tool most of the times won't work in this situation), or do I have to delete the polygon they belong to, and rebuild it? Quote Link to comment Share on other sites More sharing options...
Contributor ajz3d Posted June 5, 2016 Contributor Report Share Posted June 5, 2016 3 minutes ago, Dennis Nikolaidis said: some vertices will snap on the back of the model instead of the side I'm editing. First of all I wanted to ask if there is a way to avoid this misshap This happens frequently when you're retopologizing a thin surface or a surface on top of some other surface. Try using different snapping algorithms. It probably won't help, but there's a small chance that it will. 3 minutes ago, Dennis Nikolaidis said: I was wondering if there is a way to move those vertices back where I want (move tool most of the times won't work in this situation) Try moving your vertex to your hi-res geometry's border, and then to its target position (move it from around the edge). Sometimes it works, sometimes it doesn't. Most of the times you will need to delete your retopo faces and recreate them. Quote Link to comment Share on other sites More sharing options...
Member smatthews1999 Posted April 21, 2020 Member Report Share Posted April 21, 2020 (edited) 2020 and this is still a YUGE problem. The worst of it is that it works fine initially, and as you proceed with any brushing, snapping, etc. you will then realize that a large portion of your retopo has snapped to the other side. It makes a 2 hour job 4 hours. So sad this is still as broken AF. Edited April 21, 2020 by smatthews1999 Quote Link to comment Share on other sites More sharing options...
Carlosan Posted May 1, 2020 Report Share Posted May 1, 2020 Hi What snap method are you using ? Quote Link to comment Share on other sites More sharing options...
