Member Chilton Webb Posted December 22, 2016 Member Report Share Posted December 22, 2016 Hi, Is there a way to make a brush act like the Trim Smooth Border brush in Zbrush? Basically it uses the initial normal detected when you click, for all subsequent actions, until the mouse is released. Thank you! -Chilton 1 Quote Link to comment Share on other sites More sharing options...
carrots Posted December 22, 2016 Report Share Posted December 22, 2016 Quote Link to comment Share on other sites More sharing options...
carrots Posted December 22, 2016 Report Share Posted December 22, 2016 Hi,You can install 3D-Coat 4.7.18 and use Plane tool or Flatten tool with the option On Plane. "Type Of Surface" choose PlaneBasedBeforePaint. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted December 23, 2016 Reputable Contributor Report Share Posted December 23, 2016 To add to this, when using the Plane tool, or Flatten Brush with "On Plane" option chosen, you can walk the plane forward and backward using the + and - key on the NUM pad. Quote Link to comment Share on other sites More sharing options...
Solution Javis Posted December 23, 2016 Solution Report Share Posted December 23, 2016 I usually end up using the flatten tool with the plane option. It works almost exactly like what you're looking for. Quote Link to comment Share on other sites More sharing options...
