Member JustAnotherName Posted December 6, 2017 Member Share Posted December 6, 2017 Hey guys, I have the same problem as a while ago. Scaling on the model is ok, scene scale, measurement units, etc. everything fine. After unwrapping the upper body part I want is only 4.45x3.75cm large. I am really desperate right now. This has to work. I have some customers for made to measure garments. If I don't solve this it's really bad. Amethysta_1.3b Body.eps Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21720-scaling-problem-again/ Share on other sites More sharing options...
Carlosan Posted December 6, 2017 Share Posted December 6, 2017 The Scene Scale value is correct ?Measurement Units are CM, is ok ?Please try this version Amethysta_2.zip Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21720-scaling-problem-again/#findComment-149793 Share on other sites More sharing options...
Carlosan Posted December 6, 2017 Share Posted December 6, 2017 Switching to paint room, use Measure Tool to check again. Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21720-scaling-problem-again/#findComment-149794 Share on other sites More sharing options...
Carlosan Posted December 6, 2017 Share Posted December 6, 2017 Another option will be to import the Sculpt model to a new Fresh Project using RMB over the Voxel layer and using the command > Import 3B File.Hope this help Amethysta_2.obj.zip Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21720-scaling-problem-again/#findComment-149797 Share on other sites More sharing options...
Reputable Contributor digman Posted December 6, 2017 Reputable Contributor Share Posted December 6, 2017 (edited) I have questions... Was the model created at the right scale in another 3D package. What was your import process to get the model into the sculpt room. Once that is known more advice can be given... Why the so low Voxel resolution model. Edited December 6, 2017 by digman Quote Link to comment https://3dcoat.com/forum/index.php?/topic/21720-scaling-problem-again/#findComment-149798 Share on other sites More sharing options...
