Member MysticTeacup Posted March 26, 2018 Member Report Share Posted March 26, 2018 Hi, I am fairly new to sculpting in coat, and I am having this really weird problem that is getting on my nerves, so my model keeps disappearing and clipping when I am trying to sculpt on it, every time I turn the model or my view it sometimes disappears. I did solve this once, It stays normal when I was zoomed in at a certain point, that does still work, but the point where it is normal is very very zoomed in and I cannot see the rest of my model... It is super confusing. I thought maybe it was because it is super high poly, due to the amount of times I subdivided... I just want to be able to rotate around my model and sculpt without it disappearing. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 26, 2018 Reputable Contributor Report Share Posted March 26, 2018 It appears to more of a mesh problem than a clipping problem. You can try changing the clipping plane in Preferences... Share the 3DC file if possible if changing the clipping plane does not work. Quote Link to comment Share on other sites More sharing options...
Member MysticTeacup Posted March 26, 2018 Author Member Report Share Posted March 26, 2018 I can't even post the file as it's too large. I am just going to redo it, I think it's royally messed up beyond repair the Plane Modulator thing didn't work, I definitely did something wrong when I was sculpting, thank you for your help though! Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted March 27, 2018 Reputable Contributor Report Share Posted March 27, 2018 (edited) If in surface mode, be careful as you build your mesh. It is polygons and not voxels and is subject to mesh intersections and other generally aspects of polygon building Edited March 27, 2018 by digman Quote Link to comment Share on other sites More sharing options...
Member MysticTeacup Posted March 27, 2018 Author Member Report Share Posted March 27, 2018 I would have used Voxel, but when I put the model into Voxel it was all broken, like bits of it had just been cut out and ripped up.There was a massive rectangle missing from the top. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted March 28, 2018 Report Share Posted March 28, 2018 What is the size relationship between the model and the grid ? Quote Link to comment Share on other sites More sharing options...
