Applink Developer haikalle Posted June 30, 2018 Applink Developer Report Share Posted June 30, 2018 (edited) Hi! I think that there is a small bug with applink code. If you want to use 3DC -> Other 3D app . You press File -> Export to -> choose your 3d app. Then it will open window where to save you file. It only gives obj type to choose. After that window it will open export window. There is Output Mesh option and it will give more options (fbx, dae etc...) if I choose dae file and press export. It will save it as dae file but in applink export.txt it reads 'Object.dae.obj' Solution idea: Could we add all export types into first window and then it copys data to seconds windows "Output Mesh" box Edited June 30, 2018 by haikalle Quote Link to comment Share on other sites More sharing options...
Carlosan Posted June 30, 2018 Report Share Posted June 30, 2018 Reported. Thx ! Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted July 19, 2018 Report Share Posted July 19, 2018 Ok, corrected in 4.8.19 1 Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted July 20, 2018 Author Applink Developer Report Share Posted July 20, 2018 Thanks. Works great now. Quote Link to comment Share on other sites More sharing options...
