Textures are saved black
Wasili
  • Applink Developer
I wonder why your object is invisible in last video?
I checked your first video again and it seams that your painting your voxel object in there.
Also I see that you have two objects in "paint objects" Does your object include two meshes?
Edited by haikalle
You have 2 Surface Materials, delete the empty one Default1
If you are using PBR metalness check if are working on the right workflow
View > Metalness is showing that there isnt any map painted
Add metalness to paint over that map
I checked everything you said but still don't know what the matter is and what I have to do. I still have textures saved black. And take a look, for some reason in the texture I can draw and on the model can not http://take.ms/iUlrf
1 hour ago, Carlosan said:
Deselect export constructor shown in picture. You will get a new menu.
Make sure "Store gloss/roughness in Metal alpha is deselected.
This will export all your maps correctly.
Thank you! I removed this tick, now works) And why in texture editor paints and does not paints on the model?
13 minutes ago, Carlosan said:
Preview options is included on Brush and fill tool only with the Smart Material.
Use camera projection -noy cube mapping- to see how tiling work.
Remember that all your questions are answered in the manual. Please take a look.
Thanks for the link to the manual but still why does not draw on the model? Here's another record from the screen, here I change different projections http://take.ms/L1h0r
8 minutes ago, Carlosan said:
Try deleting options.xml on ...\user\Documents\3D-CoatV48
If you still keep using version 4.8.03 i can not help anymore, because several bugs was fixed on latest version. Please use it , sorry.
I understand, but I have the latest version does not display materials. I sent you a scene, you said you'd test and tell me why, but I didn't get a response from you.
Извините, но я не могу повторить эту проблему.
Я могу рисовать без каких-либо проблем с вашей моделью.
Что делать, если вы начнете новую сцену, используя любую модель по умолчанию, чтобы протестировать комнату Paint? (Shift + M)
The new model draws without problem  http://take.ms/TJMRv  It seems to be a bug and I would gladly draw in the new version of 3d coat but in the new version I have all objects invisible
